Studdering At Low RPM
Old Aug 3, 2003 | 02:06 PM
acura93slamed's Avatar
Default Studdering At Low RPM
My 93 Accord EX studders at low rpm , but as soon as u get to about 3,500 or 4, it takes off like no other. Anyone got any ideas? No tapping, or ticking....and idles fine.
Project93Accord
Old Aug 3, 2003 | 02:17 PM
im_the_teacher's Avatar
Default Re: Studdering At Low RPM (Project93Accord)
could be your fuel regulator is sticking open....therefore too much fuel lil air.....once u get up to high rpm more air come in to balance out ur fuel %
Old Aug 3, 2003 | 02:19 PM
Default Re: Studdering At Low RPM (im_the_teacher)
and this can be solved by?
Old Aug 3, 2003 | 05:05 PM
Voom's Avatar
Try checking your timing. Could be it, and that's really easy too.
Old Aug 3, 2003 | 06:17 PM
AngryTR0LL's Avatar
Default Re: Studdering At Low RPM (Voom)
Unplug your EGR valve. If the miss goes away, your EGR ports are clogged. You'll need to remove 4 plugs from your intake and clean the plugged ports.
-Troll-
Old Aug 4, 2003 | 03:22 PM
bill-71SS's Avatar
does it shudder at around 1800-2200rpm? if so, your EGR ports are clogged.
hondafrk
Dec 2, 2023 08:36 PM
vtecsi00
15
Aug 22, 2009 02:24 PM
vinuneuro
11
Jun 13, 2008 07:32 PM
Alpinestars21
15
Jan 29, 2004 04:46 PM
