Type R motor in a 94 civic...Civic or Type R exhaust???
Old Aug 3, 2003 | 02:03 PM
civiccat's Avatar
Default Type R motor in a 94 civic...Civic or Type R exhaust???
I have a 94 Civic EX and I'm putting a Type R motor in it....I am unsure about what kind of exhaust i should use....Type R or Civic exhaust???
Old Aug 3, 2003 | 03:45 PM
Teal95Coupe's Avatar
Default Re: Type R motor in a 94 civic...Civic or Type R exhaust??? (civiccat)
Civic
Old Aug 3, 2003 | 05:49 PM
wm5holla's Avatar
Default Re: Type R motor in a 94 civic...Civic or Type R exhaust??? (Teal95Coupe)
call midas
Old Aug 3, 2003 | 07:43 PM
B16b2b's Avatar
just search, or even better, just think about it before you post it.
Old Aug 5, 2003 | 04:50 AM
b19coupe's Avatar
Stock Civic exhaust will kill your power. Go with Type-R exhaust, slight modification will be necessary to make it fit.
Old Aug 5, 2003 | 04:59 AM
civiccat's Avatar
Default Re: Type R motor in a 94 civic...Civic or Type R exhaust??? (b19coupe)
What type of modifications would have to be made?????
Old Aug 5, 2003 | 05:14 AM
b19coupe's Avatar
It has been a while since I did my exhaust, but I think that the B-pipe (pipe between cat and muffler) is too long and has to be shortened. Go to a muffler shop with exhaust in hand, and they can make it fit for you, no problem.
Old Aug 5, 2003 | 02:07 PM
civiccat's Avatar
Thanks man I appreciate all your help.
Old Aug 5, 2003 | 03:23 PM
I thought you were talking about an aftermarket exhaust. Yes definately dont use a stock Civic exhaust on a typeR motor. If you buy a catback one made for a Civic it will fit with no modifications though.
Old Aug 6, 2003 | 06:09 PM
civiccat's Avatar
yea its going to be an APEXI N1 aftermarket exhaust....so if i get the N1 for my car, it will fit the type r motor no problem????
Old Aug 6, 2003 | 07:05 PM
realfasthonda's Avatar
yep
Old Aug 6, 2003 | 08:24 PM
highbrid's Avatar
Default Re: Type R motor in a 94 civic...Civic or Type R exhaust??? (realfasthonda)
what i do is when i swap in a b series motor, i buy a b16 header, civic exhaust and everything bolts up perfectly
HondaMan234285
Acura TL, RL & ZDX
Jul 5, 2015 06:57 PM
Oxidious
Honda Civic (2006 - 2015)
Nov 6, 2013 03:30 AM
93(Civic)EG6
Sep 3, 2007 11:12 AM
dacaveman
Dec 25, 2003 05:43 PM
