HOW DO I DISTINGUISH JDM B16 YEARS!???
Old Aug 3, 2003 | 12:02 PM
SiDelSol97's Avatar
Default HOW DO I DISTINGUISH JDM B16 YEARS!???
How can I tell if my JDM B16 swap is a 92-95 or a 96-00? I have no ecu and the harness is cut where I cant tell by the connectors. I know it is not an 88-91.
Old Aug 3, 2003 | 03:15 PM
poison's Avatar
Default Re: HOW DO I DISTINGUISH JDM B16 YEARS!??? (SiDelSol97)
Look at the head and there will be a circle near one of the exhaust header ports, it will said 9 2 or 9 5 or whatnot.
Old Aug 3, 2003 | 03:25 PM
SiDelSol97's Avatar
Default Re: HOW DO I DISTINGUISH JDM B16 YEARS!??? (poison)
But that can mean anything, my friend has one that says 93 but his is a 94 model, and another friend has one that says 95 and it is a 95, Are there any distinguishing features that the OBD2 has that the OBD1 has not?
Old Aug 3, 2003 | 04:06 PM
Kamin's Avatar
thats because the engines are made 1 year before the model year of the car
that is the only way to disguingish the year. it is correct.
Old Aug 3, 2003 | 04:37 PM
SiDelSol97's Avatar
Default Re: HOW DO I DISTINGUISH JDM B16 YEARS!??? (Kamin)
This is not always so, like I said in my previous post, on eof my friends has a 1994 year model car but it has a 93 stamp on it, and another friend has a 95 year model car and it has a 95 stamp on it. I need to know if there are any distinguishing marks between OBD1 and OBD2 motors or tranny's.
Old Aug 3, 2003 | 04:42 PM
Kamin's Avatar
are you telling me im wrong?
dude.
98% of motors are made 1 YEAR BEFORE THE CAR. there are a few same year motors but they are RARE.
just look at the year that will answer your question.
Old Aug 3, 2003 | 05:03 PM
SiDelSol97's Avatar
Well I am telling you that you are wrong, where you got that 98% figure no one will know. Back to the question I origionally had, ARE THERE ANY DISTINGUISHING FEATURES ON A JDM B16 BETWEEN OBD1 AND OBD2? Thanks.
Old Aug 3, 2003 | 06:00 PM
GOLDBERG's Avatar
well if you know hes wrong then obviously you already know the answer, so why keep asking the question?
Old Aug 3, 2003 | 06:13 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiDelSol97 &raquo;</TD></TR><TR><TD CLASS="quote">Well I am telling you that you are wrong, where you got that 98% figure no one will know. Back to the question I origionally had, ARE THERE ANY DISTINGUISHING FEATURES ON A JDM B16 BETWEEN OBD1 AND OBD2? Thanks.</TD></TR></TABLE>
go ahead and fend for yourself then
im not gonn try to explain the small diffrences between obdI and obdII engines when all you have to do is ******* listen to me.
have fun
Old Aug 3, 2003 | 06:35 PM
SiDelSol97's Avatar
The stamp on the motor says 95. So this can mean it is either out of a 95 year model car or maybe even out of a 96. That is why i am asking for any little differences that there may be in the OBD1's and 2's.
Old Aug 3, 2003 | 07:53 PM
JDMHN8's Avatar
Look at the fuel injector plugs. OBDI plugs are square and OBDII plugs are sort of oval shaped. They are very different.
Old Aug 3, 2003 | 07:58 PM
SiDelSol97's Avatar
Default Re: HOW DO I DISTINGUISH JDM B16 YEARS!??? (JDMDA9)
Thank you so much.
Old Aug 4, 2003 | 05:16 AM
SiDelSol97's Avatar
Then my motor is an OBD1 and my stamp says 95. So it must have been one of the last OBD1 motors produced since it did not go into the 96 model. Thanks for nothin Kamin.
Old Aug 4, 2003 | 07:40 AM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiDelSol97 &raquo;</TD></TR><TR><TD CLASS="quote">Then my motor is an OBD1 and my stamp says 95. So it must have been one of the last OBD1 motors produced since it did not go into the 96 model. Thanks for nothin Kamin.</TD></TR></TABLE>
you lucky he evening tried to help you out. thanks for being a retard
Old Aug 4, 2003 | 10:59 AM
SiDelSol97's Avatar
Default Re: HOW DO I DISTINGUISH JDM B16 YEARS!??? (sleeperciv)
Helping me out, he wasnt even answering my question. I was asking for distinguishing features between OBD1 and OBD2 JDM B16's. Not how to tell what year it was. JDMDA9 was very helpful in this, and I thanked him.
Old Aug 4, 2003 | 11:05 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiDelSol97 &raquo;</TD></TR><TR><TD CLASS="quote">How can I tell if my JDM B16 swap is a 92-95 or a 96-00? I have no ecu and the harness is cut where I cant tell by the connectors. I know it is not an 88-91.</TD></TR></TABLE>
This will help a little, but if you look on the topside of the head, look for this '30'.
This will designate a 92+ B16A head.
Pre 92 heads don't have this '30' insignia, also GSR heads have a '72' in the same spot:
If you own an OBD2 JDM B16A engine, there will be be no VTEC pressure switch (green plug) on the VTEC solenoid, and like the others have said, look right above the #4 exhaust port for the year of head as seen here:
Old Aug 4, 2003 | 11:21 AM
SiDelSol97's Avatar
Default Re: HOW DO I DISTINGUISH JDM B16 YEARS!??? (Katman)
I didnt think any 92+ JDM B16 had a vtec pressure switch. Please give me your insight on this.
Old Aug 4, 2003 | 11:25 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiDelSol97 &raquo;</TD></TR><TR><TD CLASS="quote">I didnt think any 92+ JDM B16 had a vtec pressure switch. Please give me your insight on this.</TD></TR></TABLE>
wrong.
Only 96+ JDM OBD2 B-series engine do NOT have a VTPS.
All JDM 89-95 B-series engine have a VTPS.
Old Aug 4, 2003 | 11:28 AM
SiDelSol97's Avatar
Hmmm....JDMDA9 told me up in the post that the OBD1's have square injector wire plugs, and that OBD2 ones have an oval shaped one. I have square one's, no green vtec plug and my block says 95 and came with an OBD1 ecu. So i am very confused as to the OBD version it is.
Old Aug 4, 2003 | 11:51 AM
SiDelSol97's Avatar
Also on another message board someone told me that if there are 2 plugs next to the distributor it is an OBD1 and if there is only 1 then it is an OBD2.
Old Aug 4, 2003 | 12:12 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiDelSol97 &raquo;</TD></TR><TR><TD CLASS="quote">Also on another message board someone told me that if there are 2 plugs next to the distributor it is an OBD1 and if there is only 1 then it is an OBD2.</TD></TR></TABLE>
That is correct. I would also advise not to flame people who have tried helping you out.
Old Aug 4, 2003 | 02:09 PM
SiDelSol97's Avatar
up
Old Aug 5, 2003 | 12:17 PM
SiDelSol97's Avatar
Old Aug 5, 2003 | 01:33 PM
The Destroyer's Avatar
Kamin told you how to find the year.
And if you put the 2 together, The year will tell you what obd the head/b16 is.
Old Aug 5, 2003 | 04:10 PM
SiDelSol97's Avatar
Default Re: HOW DO I DISTINGUISH JDM B16 YEARS!??? (MagillaGorilla)
Mine says 95 on the block, that could mean it was either for the last of the 95 models or it was made for the newer 96 OBD2 models. That is why I am asking. Thanks.
