17" Tires...205 or 215?
Old Aug 3, 2003 | 11:15 AM
JDubya's Avatar
Default 17" Tires...205 or 215?
Should i get 205/40-17 or 215 sized tires? for the 215, what size sidewall would give me the closest diameter to the stock 195/55-15 ? and what do u think of the Bridgestone Potenza S03's?
Old Aug 3, 2003 | 11:36 AM
boosted92's Avatar
Default Re: 17" Tires...205 or 215? (ALL MOTOR LS)
a 205/40 is about a tenth of an inch bigger than your stock tires, 215/40's are about 4 tenths of an inch bigger. SO with the 215/40's when your speedo shows 60 you'd actually be doing about 60.8, which is a negligable difference since your speedo is off by that much anyways.
Old Aug 3, 2003 | 11:40 AM
JDubya's Avatar
Default Re: 17" Tires...205 or 215? (boosted92)
how bad would i rub w/215's? and i'm droped on H&R Race springs...
Old Aug 3, 2003 | 12:14 PM
boosted92's Avatar
I don't think it would be THAT bad with 215's, some people run 225 BFG's. YOu might need to do a lil fender well massaging with a baseball bat tho.
Old Aug 3, 2003 | 12:19 PM
riceball777's Avatar
so3 are a really great tire if u got that kind of money but its tto rich for my blood
i would just get some toyo's or the yokohama spec 2's or the new nitto gen's
i use to run 205/40/17 and i and now running 215/40/17 and will never go back to 205's
215 is wider and wider is better and a 17 inch rim is probably 7 inches wide ppl run 205 on the stock 6 inch wide rim. so 205 dont have enough of a side wall to protect the rim. 215 are perfect 205 is no good for a 7 inch rim in my opinion
and with 215 the ride will feel much more confertable.
i would use 205 only with a 6 or 6 1/2 inch rim. use 215 for a 7 inch wide rim.
Old Aug 3, 2003 | 02:55 PM
AllmotorJunkie's Avatar
205 is kool.
Old Aug 3, 2003 | 04:38 PM
Targa250R's Avatar
be professional
Rather than paying the full premium for S-03s, I'd suggest the Kumho Ecsta MX. The MX is a very comparable tire to the S-03, but is significantly cheaper.
Old Aug 18, 2003 | 11:28 AM
WOTTEG's Avatar
I mounted Yokohama AVS ES100 (215/40/17) tires on my 17x7 +38mm Rims on a Stock-height 2000 DC2 and rubbed significantly with 80lbs of luggage and two passengers in the car.
Without the extra weight in the car, the tires rub on sharp turns (90 degree turns @ 25+ MPH), road "dips" at speed, and when descending large speed bumps. The rub spots are at the peak of the rear fenderwells, and about halfway in (from teh outside edge) on the front of the front splash-gaurds (From turning the wheel and having the outside edge of the tire rub the splash gaurd).
Discount Tire put 215s on instead of 205s. I'm waiting for the 205's to come in so we can trade them out. Hopefully I don't have to re-order the rims with a larger offset (I've heard 40 and 45 are available).
Now I worry that the AVS ES100s will not "protrude" enough to protect my rims. I'd rather compromise this than have the tires give out from excessive rubbing though. (Unlikely, but not out of reason)
What a pain.
Old Aug 18, 2003 | 11:34 AM
WOTTEG's Avatar
Default Re: 17" Tires...205 or 215? (WOTTEG)
I'd never roll my fenderwell to accomodate a tire/rim on a "street" car. The risk of rust is reason enough. Although there are preventative ways around this that I hae not seen posted here.
After "rolling the fender lip; either with a fender rolling tool, rubber malet and jack, or a baseball bat: remove the rubber liner strip completely and mask around the area wehre it used to be. Now clean this area very well, roughen it up slightly with sandpaper, and apply a few coats of truck-bed liner. This stuff seals very well and you can apply it appropriately to prevent water from collecting in there and rusting. Plus you won't have to re-apply your rubber liner strip.
Truck-bed liner has <U>many</U> uses.
Old Aug 18, 2003 | 12:26 PM
92VtecTeggy's Avatar
im happy with my 205/40/17. id go 205. IMO. good luck
Old Aug 18, 2003 | 01:15 PM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
Default Re: 17" Tires...205 or 215? (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">
i would use 205 only with a 6 or 6 1/2 inch rim. use 215 for a 7 inch wide rim.</TD></TR></TABLE>
I run 205 on my 7.5" rim...
Old Aug 18, 2003 | 04:06 PM
98coupe's Avatar
From: NOVA, but OC MD for the summers, 10th St., Tyson R.I.P, USA
I ran 205 on my 17 and bent a rim so bad that it went flat. Not enough sidewall to protect. Put 215 on barely any rubbing. on sport lines and kyb agx. 215 are the only way to go.
Old Aug 21, 2003 | 03:09 PM
WOTTEG's Avatar
Default Re: 17" Tires...205 or 215? (98coupe)
Just got back from the tire place. They replaced the 215s with 205s. The 215s rubbed significantly in the read with my +38 7" rims. The 205s do not rub at all. Front or rear.
I see what you mean about the sidewall being shorter though. They are not as tall as I had hoped. . . . The car looks much better with 215s. The 205s look annerexic, Makes me worry about scraping the rims too.
Oh well.
Old Sep 3, 2003 | 11:50 AM
Muckman's Avatar
Moderator in Chief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98coupe &raquo;</TD></TR><TR><TD CLASS="quote">I ran 205 on my 17.... 215 are the only way to go.</TD></TR></TABLE>
17 x what? 17 x 6.5, 7, 7.5????? Left out an important detail!
Old Sep 3, 2003 | 01:23 PM
l2Y4N's Avatar
it mainly relies on how wide the wheel is, as mentioned. i ran Kuhmo Ecsta Supra's (215s) on my 17x7's and they rubbed so bad even with 'massaged fenders' that i had to get new tires. 205 worked WAY better, but again only if youre running a 7" wide wheel, anything smaller, and you should be ok.
Old Sep 3, 2003 | 02:04 PM
SPOONup's Avatar
i run with 215/40/17 and its great ... will nvr go down to 205. plus u only rub if ur dropped to hell like me and if u r then its just when u make u turns.
Old Sep 3, 2003 | 02:05 PM
JDubya's Avatar
Default Re: 17" Tires...205 or 215? (integraTracer)
I ended up getting the 205's...
Old Sep 3, 2003 | 03:02 PM
SC61LS's Avatar
205's with the yokohama avs-es100's or the paradas.
Old Sep 3, 2003 | 09:49 PM
kennyvb's Avatar
go with 205/40... don't forget the gearing is also affected with diameter change...
1_clean_fg2
Honda Civic (2006 - 2015)
12
Oct 13, 2006 01:27 PM
MNsnowdaboy
Aug 11, 2006 07:27 PM
Integra21
Jun 23, 2005 09:18 PM
Doogie Howser
Jun 24, 2002 05:34 AM
SuperRice
Mar 5, 2002 09:18 AM
