Type-R LSD on GSR....Benefits?
Old Aug 7, 2001 | 09:06 PM
xsnrgsr
Guest
Posts: n/a
Default Type-R LSD on GSR....Benefits?
I was just wondering what the main benefits of a R LSD on my GSR would be (cornering, wet/dry starts etc..). Also, how much should I expect for installation?
Old Aug 8, 2001 | 03:07 PM
xsnrgsr
Guest
Posts: n/a
Default Re: Type-R LSD on GSR....Benefits? (xsnrgsr)
come on
Old Aug 8, 2001 | 03:24 PM
Go Mifune's Avatar
New User
lots of user experience detailed here: https://honda-tech.com/zerothread?id=50508
Old Aug 8, 2001 | 06:46 PM
G_S_R's Avatar
Default Re: Type-R LSD on GSR....Benefits? (Go Mifune)
does R LSD in GSR tranny = noisy? any truth to this?
Ron
Old Aug 8, 2001 | 07:34 PM
Conechaser's Avatar
Default Re: Type-R LSD on GSR....Benefits? (G_S_R)
none. My friend has a ITR LSD in his Scd GSR. I can't tell its there, well unless we are taking a turn fast or what not and you can feel both tires spinning/pulling.
Old Aug 8, 2001 | 08:08 PM
dbman96's Avatar
New User
Default Re: Type-R LSD on GSR....Benefits? (94Accord)
Your car will corner waay better under power, handle better in rain and snow, launch better, and generally do everything better if it involves your foot being on the gas pedal. No more "one-wheel burnouts" and you can floor it in any corner as soon as the front wheels are pointed where you want to go.
Old Aug 8, 2001 | 08:59 PM
ajbones's Avatar
New User
Default Re: Type-R LSD on GSR....Benefits? (dbman96)
just got itr trany with the lsd put on a couple days ago. car handles much better. car takes off much better. feels real good all around. if you have the means i would highly recomend it.
Old Aug 9, 2001 | 12:59 AM
jdmteg's Avatar
New User
Default Re: Type-R LSD on GSR....Benefits? (ajbones)
Wow The ITR tranny huh? The close gear ratio should keep you in Vtec
Old Aug 9, 2001 | 03:08 AM
PROFILES2000's Avatar
Default Re: Type-R LSD on GSR....Benefits? (jdmteg)
you should have no problem staying in VTEC in the first place
Old Aug 9, 2001 | 05:13 AM
integ_newbie's Avatar
New User
ajbones,
was that a gsr that you put the R tranny in?
if so did rpm on freeway(80-90mph) increase.
anything that you don't like about the R tranny in the gsr??(detail)
thanks,
Old Aug 9, 2001 | 12:09 PM
sikgsr1's Avatar
New User
Hello all, how much does a new Type-R tranny cost and how much to do the install?
Just curious because it sounds like I have the same problem but it sounds like its coming from the rear. Maybe a bad whell bearing?....Any suggestions.
Mike
Old Aug 9, 2001 | 12:57 PM
berkel's Avatar
Default Re: Type-R LSD on GSR....Benefits? (integ_newbie)
Hi,
An ITR lsd should not be noisy at all. My KAAZ clutch-type on the other hand makes lots of noise.
Your rpm WILL go up for a given gear at every speed. This is what it means to have closer gearing
I went one step further and put a USDM ITR Tranny in my GSR with the 4.75 JDM FD (vs 4.4).
This means my gears are even closer than a USDM ITR, I guess about 8% shorter?
At 80 mph, I'm spinning about 4700 rpm. Not that great for hwy mileage, but it's very nice to have the tight gearing...
FB
Old Aug 9, 2001 | 04:07 PM
junglistgsr's Avatar
Default Re: Type-R LSD on GSR....Benefits? (berkel)
so your saying that just from putting a ITR LSD in a car the RPM will go up in every gear? that doesnt sound right to me
Old Aug 9, 2001 | 04:13 PM
Wrath of VTEC's Avatar
Default Re: Type-R LSD on GSR....Benefits? (junglistgsr)
do u think by putting a full type R trans with the LSD in a GSR will make it any faster in the qtr???
just wondering,,if it would make a improvement id b willing to spend the 1200$$ or so on a used one
i would just like to know if it will really help
all i have is the basic I/H/E
but i have run a couple of 14.9's in the qtr
how much do u think the R trans will cut off of that time??
thanks mike
Old Aug 10, 2001 | 07:12 AM
berkel's Avatar
Hi,
I was referring to the guy who was thinking about putting a whole ITR tranny in his GSR. The LSD alone would not affect rpm, sorry for the confusion.
Someone posted that the ITR tranny in a GSR would net a few tenths in a 1/4 mile race. Not sure on specifcs. If you stay all motor I really think it's one of the best mods you can do... I'm prob a little extreme with the JDM FD though, but what can you do
FB
Old Aug 10, 2001 | 12:11 PM
i would like to get the R trans,,,
i am gonna just stay all motor for a while until i have enough $$ for a turbo,,or if the vortec SC comes out,,and has good #'s for the GSR
and if i get a turbo or SC isnt it better to go with a LS trans??
i am gonna b on the lookout for a used R trans,,
does anyone know how much time it may take off the qtr ,,if u just had I/H/E???
if i get the R trans i may just not do any more mods to my GSR,,so i can start doing stuff to my 90 civic
thanks mike
VTECcnIT
Apr 29, 2006 05:02 PM
patdemps
Jul 24, 2003 04:02 PM
SLIMJIMsi97
May 2, 2002 09:54 AM
IntegralGSR
Nov 9, 2001 03:48 AM
eg6ajk
Aug 9, 2001 07:38 PM
