Fuel Cut-off
Old Aug 3, 2003 | 12:08 AM
dvp95's Avatar
Default Fuel Cut-off
Hey, I have a 96 accord, 98 jdm h22, and 80hp DP NX setup. I just wanted to know what the fuel cut-off on my h22 is so i dont do anything stupid with the nitrous. I have been using the vafc this whole time since it seems to be more accurate than the stock accord tach(is it?). I usually shift on the vafc at 7400 rpms. What is the fuel cut-off and how do I find out what mine is exactly? Do I just leave it in neutral and rev it til it cuts off? Im scared to do that. Any damage to the engine? Thanks
Old Aug 3, 2003 | 12:34 AM
caLiH22A's Avatar
Default Re: Fuel Cut-off (dvp95)
your h22's fuel cut off point should be around ~7600rpm, if you have the stock ECU then you will not be able to go past 7600rpm. yes, the vafc is more accurate then your stock tach. considering it is wired properly. if you want to find out if your fuel cut off is at 7600rpm then just push it all the way in about 2nd gear, when the fuel gets cut off you should feel like the car is braking.
c1civic
May 31, 2004 11:12 AM
Shakes
Jan 2, 2004 08:30 AM
dvp95
Aug 2, 2003 11:59 AM
GsTeg90
Apr 8, 2003 08:23 PM
Toda Party
Mar 17, 2002 01:39 AM
