hondata and ATTS!!!
Old Aug 2, 2003 | 10:17 PM
Shakes's Avatar
space cadet
Default hondata and ATTS!!!
ok, here is proof. to dispell any old rumor or clear up anyones curiosity. this sucks, but its true. sorry guys. this is an email convo i had with hondata support.
----- Original Message -----
To: support@hondata.com
Sent: Sunday, July 27, 2003 1:14 PM
Subject: ATTS
I have a 2000 Prelude SH. my concern is that when i boost my car I will have to get a new ECU and convert from OBD II and therefor i will lose ATTS. is this true or will ATTS still work when i get a hondata? if so which one do i need to get? thank you in advance. I know that there is someone with this email addy that posts on Honda-tech.com. if you would like i will post all information sent to me or i will let you. i know that if you do it then it will be taken to heart by all SH owners. we all have major worries that any ECU change will screw ATTS therefor making us waste the money on getting an SH. thank you.
Doug A.K.A Shakes
Yes, when you swap to an OBD1 ECU to use with the Hondata system, you will loose the ATTS functionality. The Hondata you get will depend on what options you want. More information can be found at http://www.hondata.com/quicktour.html.
Hondata Inc
2341 W. 205th St. Suite 106
Torrance, CA 90501
310.782.8278
310.782.6383 FAX
Sent: Thursday, July 31, 2003 10:37 PM
Subject: Re: ATTS
is there anyway that i can keep ATTS while getting a hondata? i.e. do you have an OBDII system?
There is no way to keep this with a Hondata, as we do not offer any systems for an OBD2 ECU.
Hondata Inc
Torrance, CA 90501
310.782.8278
310.782.6383 FAX
CLIFF NOTES: you can not get a hondata and keep ATTS.
Old Aug 3, 2003 | 08:11 AM
flyrod's Avatar
Default Re: hondata and ATTS!!! (shakes)
If you like ATTS that much, you may be able to hook up both ECU's. Use the OBD1 to control the engine, and the original ecu to control ATTS. Don't ask me the details on how to do this though. I know zip about ATTS; does it have a separate controller like the ABS unit, or it is built into the ECU? The original ecu will proably need some of the engine inputs, but just put resisitors on the outputs you want to control with the OBD 1 ecu. It will probably be hard to get the original ecu to run without a CEL, but it may still control ATTS fine. Get out your wiring diagrams and start splicing... Or just get a quaife and toss the ATTS and obd 2 ecu.
crampinyourstyle
Aug 17, 2006 10:41 AM
CRXLST
Nov 23, 2004 07:39 AM
sijgx
Jul 27, 2004 07:03 PM
JunIntegra
Apr 8, 2004 06:44 PM
Renegade
Jan 17, 2003 09:10 AM
