need help on what size tire is needed to go through traps in 4th gear....
Old Aug 2, 2003 | 09:58 PM
gritsak's Avatar
Default need help on what size tire is needed to go through traps in 4th gear....
my friends got a 92 hatch with turbo gsr motor/gsr trans...hes got the rev limit set at 8200 and at the end of the 1/4 its hitting rev limit in 4th gear pretty bad (around 120mph traps)...so without changing the rev limit (its not tuned beyond 8200) and without changing any gearing...what size tire does he need to be able to around 125 in 4th?..right now hes got 205-50-15 drag radials.....looking for sizes in street tires and for slicks....TIA
Old Aug 2, 2003 | 10:05 PM
Pelican's Avatar
Default Re: need help on what size tire is needed to go through traps in 4th gear.... (gritsak)
Go here http://www.jadesupra.net/gears/index.html
I forget what 4th gear and Final drive a GSR is but put that into the grid (FD is Axle ratio) and mess with tire sizes until you get 125 at 8200.
But remember, a slick will have close to 1 inch of expansion turning that fast.
HTH
Old Aug 2, 2003 | 10:16 PM
gritsak's Avatar
Default Re: need help on what size tire is needed to go through traps in 4th gear.... (Pelican)
cool thanx...i found the ratios and put everything in and its saying that it should be able to go 124mph in 4th right now but my friends hitting rev limit 3 times before going through the traps at 120 so something must be off a little
Old Aug 2, 2003 | 10:19 PM
Pelican's Avatar
tire wear?
or tach is off
Old Aug 3, 2003 | 07:31 AM
1.8T_EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pelican &raquo;</TD></TR><TR><TD CLASS="quote">Go here http://www.jadesupra.net/gears/index.html
HTH</TD></TR></TABLE>
... sweet link!!!... here is the info i used for a gsr (got it from hybridgarage) :
axle ratio - 4.4
first gear - 3.23
second gear - 2.10
third gear - 1.45
fourth gear - 1.10
fifth gear - .848
sixth gear - 0
b00st4life
Oct 8, 2014 02:58 AM
MoiMotorsports
Aug 3, 2010 04:46 PM
g2turbo
Mar 5, 2005 06:36 PM
Malice
Jan 13, 2004 05:43 PM
