Is This a Clutch/Flywheel Cover?
Old Aug 2, 2003 | 05:56 PM
Unjockable's Avatar
New User
Default Is This a Clutch/Flywheel Cover?
Old Aug 2, 2003 | 06:08 PM
ragejed's Avatar
Default Re: Is This a Clutch/Flywheel Cover? (Unjockable)
Type r brace, gose under engine, bolts to the block and tranny by the oil pan
Old Aug 2, 2003 | 06:36 PM
MooreBoost's Avatar
Default Re: Is This a Clutch/Flywheel Cover? (ragejed)
Would this limit engine movement like the Js racing damper?
gmoore
ragejed's Avatar
Default Re: Is This a Clutch/Flywheel Cover? (tegunderpressure)
no
Old Aug 2, 2003 | 10:34 PM
Downey's Avatar
yes. its from a type r. its more of a brace compared to the one on a GSR or B16
Old Aug 2, 2003 | 10:40 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
That particular one for the ITR functions as both the flywheel cover and the engine stiffener (2 separate smaller stiffeners and a separate sheet metal cover on GS-R's). The function of the stiffeners is to help further connect the block/trans bellhousing assembly together and make it a single stiffer unit, so as to lessen any possibility of wearing out crankshaft/tranny shaft bearings.
Old Aug 3, 2003 | 07:17 AM
tvrsir's Avatar
Default Re: Is This a Clutch/Flywheel Cover? (PatrickGSR94)
can this piece be used in gsr or b16 blocks.
Old Aug 3, 2003 | 02:22 PM
BI8B's Avatar
Default Re: Is This a Clutch/Flywheel Cover? (tvrsir)
so i can use this as a flywheel cover? fits any b-series motor/tranny?
SlowB16si
Sep 22, 2006 03:51 PM
Hatch It
Jun 7, 2005 02:08 PM
Toadfart
Dec 13, 2004 03:34 AM
lildrgn2.0
Jun 22, 2004 06:56 AM
