Winter project engine build up suggestions/critiques
Sometime this month, I will be installing the following setup on an '00 d16y7:
Greddy turbo kit
Greddy type 31 FMIC
Greddy type s BOV
Greddy profec B
440cc injectors
hondata s100b
and I plan on running 8psi daily, 10psi at the track with the stock internals. I know that I am going to happy with that setup for a little while but I know that I am going to want more so I am trying to put together a winter project build up to handle more boost. My first question is, how much boost can the greddy kit handle and still be efficient? For the winter buildup I am probably going to go with eagle rods and JE pistons. What else would you guys suggest that I add so that I can run 14-15psi with this setup? I know that for 8-10psi my hondata tuner told me I would be ok with the stock fuel pump, but I know that I will need a 255lph for that much boost. Any suggestions are greatly appreciated.
Pfieff
Greddy turbo kit
Greddy type 31 FMIC
Greddy type s BOV
Greddy profec B
440cc injectors
hondata s100b
Pfieff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pfieffdog »</TD></TR><TR><TD CLASS="quote">Sometime this month, I will be installing the following setup on an '00 d16y7:
Greddy turbo kit
Greddy type 31 FMIC
Greddy type s BOV
Greddy profec B
440cc injectors
hondata s100b
Pfieff</TD></TR></TABLE>
I would also suggest Eagle rods with the upgraded rod bolt option and Endyn Wiseco pistons.
Since you are going this route, I suggest you sleeve it while it is all apart. My $.02.
Greddy turbo kit
Greddy type 31 FMIC
Greddy type s BOV
Greddy profec B
440cc injectors
hondata s100b
