Just checking:b18b to ek wiring question.
ok i have a obd2 b18b going into my 97 civ HB. wiring wise i dont have to change any harnesses. just plug and play? im staying non-vtec to go boost later. i just want to confirm this.
https://honda-tech.com/zerothread?id=558245
Probably the best write up on wiring in a ek for any b series swap... enjoy.. compliments of KATMAN
You have to use the CX or DX harness that came in your car.
Take that harness and put it on the B motor.
Switch the ecu pins and sensor plugs where needed.
That's it.
check the "EK Swap Guide" link in my sig.
Modified by Trey at 9:10 AM 8/3/2003
That's it.
actually grab a EX wiring harness.. and throw it in there..i am doing the exact same swap as u.... and katman told me to grab a EX wiring harness... and it plugs right up.. and just leave the vtec wire hanging.. and the good thing about that is... if u ever do decide to go vtec or grab a vtec head... u already have the vtec wiring right there... and that's it.. plug and play with the EX harness... other wise u have to convert the IACV from 3-wire -to- 2-wire it's easy from what i hear... but y not make it easier.. ya know!?
U can pick up a wiring harness for a EX for like $100+ from like a junkyard or something...
:sigh:
Actually the CX and DX harness will do fine if you are on a tiiite budget (pun intended).
EX harness is butta. ( I used the EX as well cuz I was lazy)
enot767
12
Jul 17, 2009 02:27 PM
Sinista
Jan 19, 2006 05:00 AM
