How much psi do you run in your slicks?
Old Aug 2, 2003 | 12:32 PM
fast93accord's Avatar
Default How much psi do you run in your slicks?
How much psi do some of you guys/girls run in your dragslicks. I have mine at 18psi right now, and just curious what everyone else is running. Thanks.
Old Aug 2, 2003 | 12:38 PM
ZEX Man's Avatar
Default Re: How much psi do you run in your slicks? (fast93accord)
24.5 x 9 x 13 MT's, with tubes = 7.5 psi
Later,
ZEX Man
Old Aug 2, 2003 | 12:39 PM
SlicksMH's Avatar
It just depends on how the track is, I was up in vegas and my guy's were going up from 7-psi to 11-psi and even higher. John@M&H
Old Aug 2, 2003 | 01:45 PM
hybrid901's Avatar
Default Re: How much psi do you run in your slicks? (SlicksMH)
7-8psi
Old Aug 2, 2003 | 02:09 PM
LSiTurbo's Avatar
Default Re: How much psi do you run in your slicks? (hybrid901)
6.5 psi 22x9x13 M&H 1.65 60' 12.4@108 allmotor nonvtec
Old Aug 2, 2003 | 07:45 PM
smokey2.0's Avatar
john, 13x8x22(might not be the right size) size slick, what psi?
Old Aug 2, 2003 | 07:50 PM
ExospeedAMcrx's Avatar
Default Re: How much psi do you run in your slicks? (smokey2.0)
smokey: try starting at 12 psi and work your way down as you need to. If it feels like you're still spinning the tire at the launch... drop 1psi at a time and see when it start feeling good and hooking up.
Wil
Old Aug 2, 2003 | 08:32 PM
SlicksMH's Avatar
Why do you think this is the wrong size slicks? I will IM you. John@M&H
Old Aug 2, 2003 | 08:57 PM
smokey2.0's Avatar
Default Re: How much psi do you run in your slicks? (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">smokey: try starting at 12 psi and work your way down as you need to. If it feels like you're still spinning the tire at the launch... drop 1psi at a time and see when it start feeling good and hooking up.
Wil</TD></TR></TABLE>
thankx will
Old Aug 3, 2003 | 11:21 AM
Jared's Avatar
Mine hooks best between 7 and 8psi depending on track conditions.
Old Aug 3, 2003 | 11:28 AM
Boostfed's Avatar
New User
Default Re: How much psi do you run in your slicks? (Jared)
Usually about 9-10, going lower get's shakey up top IMO. WHOAH! I will try different air pressures this year again. I have cut a 1.67 60' before with 9psi in the slicks 24.5x7x13
Old Aug 3, 2003 | 11:34 AM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">Mine hooks best between 7 and 8psi depending on track conditions.</TD></TR></TABLE>
what size slick jared?
Old Aug 5, 2003 | 04:42 AM
Mista Bone's Avatar
D Tranny Guru
SOHC Civic
20x8x14 MT's at 12 psi
20x6x14 MT's at 14 psi
22x8x13's M&H will get it next.
BTW 1.816 from a 20x8x14 MT at 12 psi?????
Why yes I did!!!
Old Aug 5, 2003 | 06:57 AM
Default Re: How much psi do you run in your slicks? (Mista Bone)
ya bone.. i was surprised at those 20x8x14 M/T when I was able to cut a 1.7 60ft.
I was always stuck at 1.83's. GOOD SLICKS!
Old Aug 5, 2003 | 09:47 AM
smokey2.0's Avatar
damm, now i'm confused. will a 22x8x13 slick be the the right choisce for my 88 crx, the set up i have there now is making 200 WHP. i would like to know, before i put money into a set of rims and slicks! TIA
Old Aug 5, 2003 | 10:37 AM
SlicksMH's Avatar
Yes John@M&H
Old Aug 5, 2003 | 11:21 AM
mopar junkie's Avatar
Smokey, 22x8x13 is a tad small for 200whp. Might be just right depending on your axle ratio. If you have really short gears you might want a 23" or 24.5" slick.
Old Aug 5, 2003 | 12:32 PM
smokey2.0's Avatar
Default Re: How much psi do you run in your slicks? (mopar junkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mopar junkie &raquo;</TD></TR><TR><TD CLASS="quote">Smokey, 22x8x13 is a tad small for 200whp. Might be just right depending on your axle ratio. If you have really short gears you might want a 23" or 24.5" slick.</TD></TR></TABLE>
dude, thanks for the input, but john@M&H cleared things up for me. we spoke for about 20-30 minutes, he went over my final drive and gear ratios. he made me understand why the 8/22-13 slick will work in my application, but he also made me understand that if i fork up 500 bucks on some 8/13" rims that my money would be well spendt! john@M&H gets from me
Old Aug 6, 2003 | 03:53 AM
Mista Bone's Avatar
D Tranny Guru
I'm stepping up to the 22x8x13 M&H slicks as soon as money allows. (singlecam SLEEPER, thanks for the ET's!)
John@M&H, I watched a set of M&H slicks be DESTROYED in one day with only 12 passes. A new Neon SRT-4 driver had a set of 15" slicks at 6 psi. After 6 passes I could no longer read the slick size on the sidewall!!!!!!!
Exospeed and others, the 20x8x14 MT NEED at 14x7-8" rim. I've always ran mine on a TSW Alpine 14x6 rim and have suffered wear issues. I get bad wear on the outer edges and the slicks last about 150-200 passes. I went thru my second pair. A buddy with same slicks on 14x7 rims has 225 passes with even wear.
I do WARM up the slicks......this is how they were the most consistant........
Mind you I'm not a big name racer, but I know MY setup. I have 500+ passes on slick in MY car, I know how it SHOULD react. 700+ passes in my car since I've owned it.
I launch at 7000 rpm or MORE with the SOHC, juice or no juice!!!!!!!
Old Aug 6, 2003 | 04:04 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
I run 7psi in my 25x8x13 M&H's, no tubes. Heres a pic of them hard-at-work, hehe
Old Aug 6, 2003 | 05:28 AM
SlicksMH's Avatar
Do you know why you Destroyed the slick and could not read the # on the sidewall , because you were running ( TOO LOW OF AIR PRESSURE ) and the M&H slicks were not designed too run that low, would you go down the freeway with your passenger tires @ 6-psi I don't think so. John@M&H
Old Aug 6, 2003 | 09:03 AM
I ran my M/T 20x8x14 on some Bogart 14x8 wheels
they looked good
Old Aug 6, 2003 | 09:21 AM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote"> Bogart 13x8wheels </TD></TR></TABLE>
where can i or anyone of us find the best price for these rims, is there a cheaper alternative to using these rims?
Modified by smokey2.0 at 10:15 AM 8/7/2003
Old Aug 6, 2003 | 09:37 AM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlicksMH &raquo;</TD></TR><TR><TD CLASS="quote">John@M&H, I watched a set of M&H slicks be DESTROYED in one day with only 12 passes. A new Neon SRT-4 driver had a set of 15" slicks at 6 psi. After 6 passes I could no longer read the slick size on the sidewall!!!!!!!
Do you know why you Destroyed the slick and could not read the # on the sidewall , because you were running ( TOO LOW OF AIR PRESSURE ) and the M&H slicks were not designed too run that low, would you go down the freeway with your passenger tires @ 6-psi I don't think so. John@M&H</TD></TR></TABLE>
Just to clarify John, Mistabone wasn't theone who ruined his slicks, he said it was some Neon SRT4 driver that did it.
Old Aug 6, 2003 | 10:05 AM
SlicksMH's Avatar
Default Re: How much psi do you run in your slicks? (Boostfed)
Thank You (Boostfed) and Mistabone SORRY SORRY SORRY, racer's get the wrong imfo and that is why I am on H-T to help all you racer's out, Safety Safety Safety comes #1, guy's IM me I don't mind @ all I LOVE what I do and I am here to help you be safe and go Faaaaaaaast. Mistabone sorry for the mix up. John@M&H
