Skunk2 D Series Intake Manifold Sellers and Owners,I need this measurement.....
Old Aug 2, 2003 | 12:27 PM
D-Man's Avatar
Default Skunk2 D Series Intake Manifold Sellers and Owners,I need this measurement.....
This is off a D16A,its 9.75" tall as you can see from the below pics.
The D16Z is 10.25" tall.
The D16Y is 10.50" tall.
(update)The Skunk2 is 12" tall
Modified by D-Man at 8:58 PM 8/2/2003
Modified by D-Man at 9:29 PM 8/3/2003
Old Aug 2, 2003 | 02:09 PM
singlecam screamer's Avatar
Default Re: Skunk2 D Series Intake Manifold Sellers and Owners,I need this measurement..... (D-Man)
well i already have mine on the car but i measured it and to the back of the iac valve 13 1/4" it's way longer than the z6 im
Old Aug 2, 2003 | 05:03 PM
D-Man's Avatar
Default Re: Skunk2 D Series Intake Manifold Sellers and Owners,I need this measurement..... (singlecam screa
thanks!..now I gotta measure one of my iac valves for the heck of it cause at 13 1/4 I dont think thats gonna fit in my 91 which measures approx 12.5" from cylinder head to firewall...oh well,i'll just have to save my money for something else
Old Aug 2, 2003 | 05:10 PM
here's a pic of it on my car
but it sure is a nice piece,just sell the 91 and buy a 92 lol
Old Aug 3, 2003 | 04:57 PM
ladysman's Avatar
Get the Y8 manifold. I have one for sale.
https://honda-tech.com/zerothread?id=581405
Old Aug 3, 2003 | 05:26 PM
D-Man's Avatar
No Thanks..I have 1 sitting around somewhere...Maybe one day I'll see someone make a real turbo manifold that bolts on all the Honda Sensors like a Edelbrock Victor X for a D...it's just too bad Skunk2 designed this for N/A but what can we expect from a company that's NA biased anyway
BTW..I still cant believe they made this manifold that tall! I can imagine how many 88-91 guys that will be in for a surprise when they buy and try to install this manifold
Modified by D-Man at 9:37 PM 8/3/2003
Old Aug 3, 2003 | 11:14 PM
RyanEJ8's Avatar
Damn, I think that be in the way of my ZEX box. Hey Singlecam Screamer, how about getting a dyno comparison? Let us know how much you gained.
Old Mar 9, 2004 | 09:15 AM
Marauder's Avatar
The Edelbrock Performer X manifold is almost 12" to the back of the plenum, and 12.2" for the little part of the idle passage that sticks out past the plenum.
The IAC mounts under the manifold for firewall clearance, and all the vacuum connections install under the plenum for clearance as well. Much cleaner install than the Skunk manifold.
Old Mar 9, 2004 | 10:37 AM
D-Man's Avatar
Thanks! ...I guess its too close for comfort on a EF,only leaves me with like .3" clearance between it and firewall
Old Mar 9, 2004 | 11:18 AM
Marauder's Avatar
How close to the firewall does the TPS sensor come?
You made all the measurements to the manifold, but since the throttle body is straight, the closest item to the firewall is the TPS sensor. You should compare the measurement from the intake flange to the TPS to that of the Edelbrock manifold.
Whats the distance from the flange to the back of the IAC motor?
Old Mar 9, 2004 | 11:28 AM
Marauder's Avatar
The IAC motor is 1.4" thick, and the bolt head is another .3".
So adding that to the other manifolds, its
10.2 inches tall for the D16A manifold.
12.2 inches for the D16Y
11.7 inches for the D16Z
Old Mar 9, 2004 | 12:04 PM
gitwidit's Avatar
Good info
Old Mar 9, 2004 | 12:48 PM
D-Man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">How close to the firewall does the TPS sensor come?
You made all the measurements to the manifold, but since the throttle body is straight, the closest item to the firewall is the TPS sensor. nifold.
Whats the distance from the flange to the back of the IAC motor? </TD></TR></TABLE>
The firewall curves in at the higher location the TPS sits at so there is more room than at the IAC location,also there is a brake line connector by the IAC that screws things up too...so it dont matter measuring over there(the TPS).
charlie_sohc
Jul 2, 2007 02:04 PM
singlecamkilla
Mar 7, 2006 08:40 PM
AnthraxVX
Feb 28, 2006 10:40 PM
