parting out a zc engine...and some si tranny's
ok, i have a 90 zc engine. the engine seized up on me and found that it was the crank thrust bearings. My guess is that the crank would need some machining as well as the main cap. I have removed the pistons and rods but other than that if anyone needs a part just pm me with a reasonable offer
i also have two crx si tranny's. both 89's and both have slight grinds in third (very common) these would be great if you knew how to replace the sincro's. should be able to find some dx sincros at the junkyard that will fit. $50 firm for a tranny
I would prefer pick up only unless its a small engine part. thanks!
Nooch
17
Nov 28, 2012 09:42 PM
