b16a problems still
Old Aug 7, 2001 | 05:31 PM
GeeSeeR's Avatar
New User
Default b16a problems still
I just rewired my harness with the hasport subharness, but I still get a cel and it throws 2 codes one for map sensor and the second for IAC problem is the car still runs a little rich. At wot the car puffs out gas fumes are these codes the problem? Also will these codes disable Vtec? I just don't feel the vtec pull like I did when I had my gsr.
Old Aug 7, 2001 | 08:42 PM
civicracer125's Avatar
New User
Default Re: b16a problems still (GeeSeeR)
dude check your harness on those sensors to make sure the wires are pushed in all the way==== let us know how it does at the track when you get it running right. where did you get your motor? how much did you pay for everything?
Old Aug 7, 2001 | 11:06 PM
raene's Avatar
I threw a TPS code when my map sensor tubing wasn't fully connected all the way. Don't ask how they're related, I really don't know... . Let me check my code sheet here.
So I take it you're getting a code 14 and a code 3 or 5? I don't think these codes will put it into backup mode, but I'm not sure...
Preferio
Jul 6, 2005 08:56 AM
jdmslim
Mar 28, 2005 03:22 PM
dsadas89das78934
11
Aug 27, 2004 06:47 AM
k4ff1n3
Oct 23, 2002 09:38 PM
