B-series with 95mm Eagle crank
Old Aug 2, 2003 | 08:33 AM
mesquiteman's Avatar
Default B-series with 95mm Eagle crank
Has anyone had good success with this setup with out using a deck plate? I like to know if this is the hot ticket to full race N/A motors. The rumor for some racers are 300HP plus some at the wheel on their race car but only running low 11's passes. I would like to hear it from the BIG BOYS or anyone who has used it.
Old Aug 2, 2003 | 09:23 AM
granada_sun's Avatar
search search search search search, but with a 95mm crank, 300 is an understatement.
Old Aug 3, 2003 | 06:59 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (granada_sun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granada_sun &raquo;</TD></TR><TR><TD CLASS="quote">search search search search search, but with a 95mm crank, 300 is an understatement.</TD></TR></TABLE>
I doubt he will find much under search. Check the Drag forum. A lot more Pro's especially All Motor guys hang out there and can give you more info. 95mm crank is going to be shortlived in a street car. If you are going deckplated and race. Cool. 300 and understatement? Umm I don't doubt that it can't be done with $, but hwo many people make over 300whp N/A right now? Probably count em on 2 hands from the Honda camp B-Series.
Old Aug 3, 2003 | 07:44 PM
So, not that many people want to spend the money, but it doesnt mean that the power can't be made....i mean a 95mm crank? come on....street car doubtful, full drag no problem.
Old Aug 5, 2003 | 07:25 PM
StorminMatt's Avatar
The Dart tall block would be the way to go with a 95mm stroke. On a stock block without a deck plate, don't expect the engine to last. The rod ratio would be HORRIBLE. We are talking well under 1.50:1. You could improve things with a deck plate. But after resleeving AND installing a deck plate, you are probably at least close to the ~$2000 cost of a Dart block, if not over it.
Old Aug 5, 2003 | 07:48 PM
allmotorhatch's Avatar
Im running a 95mm crank, ge deck plate, we'll see how she runs when I finally get the motor in the damn car
phoshyzzle
May 25, 2008 10:02 PM
OOOtony
Dec 2, 2006 08:14 AM
aquarius
Feb 4, 2005 03:12 PM
tunerz
Nov 7, 2003 09:49 PM
