Legend GS rotors + itr calipers?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Integra »</TD></TR><TR><TD CLASS="quote">woudl the itr calipers work with the legend gs rotors?</TD></TR></TABLE>
yes it will fit, you might have to cut the rotor a little, no biggie.
Thanks for all the help guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R »</TD></TR><TR><TD CLASS="quote">do a search...</TD></TR></TABLE>
it has NEVER been covered before.. thanks for the useful advice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR »</TD></TR><TR><TD CLASS="quote">Is it necessary to upgrade the rear brakes to keep the braking process balanced?</TD></TR></TABLE>
Yes, to a point. The ABS has algorithms to take things into account, such as stickier tires, but there is a limit. What it is is known mainly to Honda engineers.
You should use a pad as aggressive as you use up front, perhaps more so, like carbotech bobcat, at the rear.
The clamping force of ITR calipers and non-ITR would be the same since both use 57mm pistons. There is more leverage to be had w/ 11.1" rotors over 10.3", but the difference is less than 10%, based on diameter. Stiffness of the caliper also plays some part, so let's say 10% is total diff.
Non-ITRs use organic pads in back, so by upgrading these to a better pad, you should get more rear bias, which can then counteract increased front bias.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bill Hook »</TD></TR><TR><TD CLASS="quote">
good info
so what differs from a non R caliper vs an iTR caliper?
good info
As you've read from your other post, it is bigger and stiffer and has more clearance for a thicker rotor (also it mounts slightly different, due to differences in ITR knuckle and hub).
The only thing the same between it and non-ITR is the piston is the same, so they should have the same clamping force, to a large extent. Calipers that flex more aren't quite as efficient, so there would be less clamping force on non-ITR calipers, but I doubt that it represents a significant difference.
i am under the impression that the itr, nsx, and v6 legend calipers are all the exact same dimesions but the nsx and legend calipers have 2 pistons. however, i could be mistaken.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid »</TD></TR><TR><TD CLASS="quote"> exact same dimesions but the nsx and legend calipers have 2 pistons.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bill Hook »</TD></TR><TR><TD CLASS="quote">Legend and NSX are two pot calipers.</TD></TR></TABLE>
and the differential bore is slightly different on the two.
SilverDc2
Jun 4, 2003 07:46 AM
