2.22 60ft at track with Advan A032R with 10psi, Is this good?
Old Aug 1, 2003 | 10:59 PM
crazyitr's Avatar
Default 2.22 60ft at track with Advan A032R with 10psi, Is this good?
First time out at the track in a 95 Civic Coupe with b16 turbo and 7psi boost.
This setup yields 225 whp. Got the 60ft down to 2.22 with 5000 rpm launch. I dropped the tire pressure to 10psi and the tires hooked. Almost seemed liked it bogged. Is it possible to get a better 60ft with the Advans. 205/55/15 from Tire Rack. I was thinking about BFG drag radials. Input? Car ran 13.74 @104 with this launch.
Old Aug 1, 2003 | 11:05 PM
Dr.OnPoint's Avatar
Default Re: 2.22 60ft at track with Advan A032R with 10psi, Is this good? (crazyitr)
Its pretty good. But you can improve you 60', even with those tires. If u get the BFG's expect to pull some 2.0 60'.
Old Aug 2, 2003 | 12:02 AM
SEFIxCivic's Avatar
those tires absolutely suck for drag racing. they are heavy tires with an extremely stiff sidewall.
Old Aug 2, 2003 | 04:22 PM
Civic_95_Si's Avatar
I got a 2.20 on some Yokohama all seaons@ 20psi. With my D16Z6 pushing a whoping 110WHP.
Old Aug 2, 2003 | 04:42 PM
SoCal ITR's Avatar
Default Re: 2.22 60ft at track with Advan A032R with 10psi, Is this good? (Civic_95_Si)
I think your pressure might be too low.
Old Aug 3, 2003 | 01:24 AM
MPower332TI's Avatar
Default Re: 2.22 60ft at track with Advan A032R with 10psi, Is this good? (SoCal ITR)
Your pressure is way to low and those tires do suck for drag racing. I have a set on my car and i got a 2.20 60ft time. I havent been back to try and get a better time. The sidewalls are just so stiff and they also need to be hot to grip. Run about 20psi and do a nice little burn out to get them hot.
Old Aug 3, 2003 | 05:41 AM
AussieK24's Avatar
What does your car weigh? I wouldnt go lower than 12psi and I've only got 1100lbs on the front tyres. I cut a 1.98 on 205/60 x 13 A032's but, yeah, too stiff a sidewall.
Old Aug 3, 2003 | 01:08 PM
STEALTHMODECOUPE's Avatar
Default Re: 2.22 60ft at track with Advan A032R with 10psi, Is this good? (AussieB20vtec)
wow its like de ja voo (sp?) a buddy of mine had a 97 coupe w/ b16 turbo on 7psi and got a 2.2 60 ft and ran 13.7@104 L0L
adaM
Old Aug 3, 2003 | 03:02 PM
Pengo's Avatar
Default Re: 2.22 60ft at track with Advan A032R with 10psi, Is this good? (STEALTHMODECOUPE)
damn i've never even run my drags that low. i think that borders on dangerous but that could just be me. i know a guy running consistent 1.9 60 fts on bfg drags
Old Aug 3, 2003 | 11:19 PM
MrIllegalX's Avatar
Could be better. I do a 2.4, and I'm slow. New tires, higher tire PSI, launch at a lower RPM and see how you do.
accord99power
May 27, 2009 03:17 PM
new411
Oct 16, 2005 08:16 AM
M15
Oct 6, 2005 07:53 PM
old_school_dohcvtec
Mar 14, 2005 06:08 PM
raene
Oct 2, 2002 05:40 AM
