dc2 integra seats in ef?
you need to swap the rails closest to the center of the car. For the outside rails (which are a couple of inches off of stock mounting holes) just go buy some strips of metal from home depot and drill 2 holes in it, one where the teg rail will mount to it and one where the stock hole is.
heres a pic of mine installed.
so, if i use the teg rail, i have to make a 'bracket' but if i swap the inner rails, im good to go?
looks sweet, i have the same color seats.
I have the same seats too. I used 95 integra seats. I didnt change the rails. One bolt lines up, I made two brackets for two bolts and drilled the last hole and used a course thread bolt with a washer. I can take pics for you if you'd like. I got the metal piece from home depot and used cardboard to make templates. I know it sounds ghetto but it did the job.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF »</TD></TR><TR><TD CLASS="quote">so, if i use the teg rail, i have to make a 'bracket' but if i swap the inner rails, im good to go?
looks sweet, i have the same color seats.</TD></TR></TABLE>
no. when you use the inside rail off the civic 2 holes line up. Then you make brackets for the other 2 holes cause they are a couple inches off.
i had 95 blakc leather gsr seats in mine. for the front just drill through the floor and put a nut and bolt in and that ***** will stay in tight. for the back drill your own holes for the 2 clips and the back part of the back seat goes right in. theres a 3 inch gap on each side of the back seat though but *** it it looks tightt.
heres the photo album...
http://community.webshots.com/album/64932878dFumdQ
(can some one post the pic, i suck at that)
first u take off the top half of the teg seat, unbolt the 2 bolts on the hinge (on lower seat) and the nut holding it on the other side, next pull up the zippers on the back on the seat so u can take out the hinge completely, now do the same to your crx seats, take the hinges off and put them on the teg seats (edit i cut my hinges and welded them "foward more" u dont have to do this but it prevents the seat from being way to reclined in the fowardmost position)
next take the cloth off the teg pan and the foam, there is little bent over staples, remove them and do the same with the crx pans, now place the foam on the crx pan along with the fabric, and zip tie em to the holes that the staples were on.
bolt it all back together and u should have a seat consisting of
integra top half
crx hinge
crx pan and rails
and teg bottom cusion and fabric
and yes the crx hinge bolts up no problem to the teg seat
its a bit confusing but its easy once u start
good luck
integra top half
crx hinge
crx pan and rails
good luck
Thanks for the inspiration! I had 2 seats in my living room for 2 years because I was afraid of putting the Acura seat in my drivers side because if I had put it in, my head would stick out of the sunroof. The idea of using the CRX pans was ingenious. I followed your instructions and it worked as stated.
After everything was assembled, I placed the hybrid unit un my 1990 CRX Si/ZC and part of your original post came to light. The most forward "lock" position of the hybrid seat has an exaggerated recline position. Not too practical. I don't have access to a cutting torch (or welder for that matter) to use the Acura Integra hinge.
I found another solution. The metal vertical rail that the seat back bolts to has 2 bolt holes. I unzipped my Acura top cover off of the seat-back and revealed the bolts. I left the lowest one in place and drilled another hole 15 degrees forward (drivers side) for the upper bolt. I put the existing bolt through the new hole and found a nut (incredibly) and tightened it up.
PERFECT ANGLE!
Modified by gentlemanjason at 10:01 PM 4/24/2006
PERFECT ANGLE!
Hey I just picked up some 99 itr seats and im having trouble installing them. Can you please help with the install? I have till sat (29th) for hot import nights in pleasanton ca, and would really want to have them on by then. Thanks and will apreciate the help.
Originally Posted by EF’n Around;[url=tel:52426053
52426053[/url]]Can you bless me with this knowledge? Lol
