My tuned GSR motor, 181.8/131.2.
Old Aug 1, 2003 | 09:29 PM
Casey's Avatar
Default My tuned GSR motor, 181.8/131.2.
I got my JDM GSR motor tuned today. Numbers speak for themselves, more than i thought id get, very pleased with the results. Mods are:
JDM GSR
toda bs portflow springs and retainers
cam gears
jdm header (open header)
k&n on a stick
hondata
skunk2 IM
ITR TB
Old Aug 1, 2003 | 09:31 PM
Erik_Pb_Foot's Avatar
New User
Old Aug 1, 2003 | 09:50 PM
aLLjDMRalf's Avatar
Default Re: My tuned GSR motor, 181.8/131.2. (Casey)
nice #'s hopefully i can get my motor to react that way
Old Aug 2, 2003 | 12:02 AM
GSRswapandslow
Guest
Posts: n/a
damn.....flattest torque i've ever seen on a vtec engine
but your torque starts to fall after the vtec engagment. try setting it back some....seems like you have it too high.
Old Aug 2, 2003 | 02:06 AM
AllmotorJunkie's Avatar
Impressive #'s
Old Aug 2, 2003 | 03:15 AM
Broken Gearbox's Avatar
Default Re: My tuned GSR motor, 181.8/131.2. (AllmotorJunkie)
nice numbers.
Old Aug 2, 2003 | 03:29 AM
preluda92's Avatar
Default Re: (GSRswapandbanned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandbanned &raquo;</TD></TR><TR><TD CLASS="quote">damn.....flattest torque i've ever seen on a vtec engine
but your torque starts to fall after the vtec engagment. try setting it back some....seems like you have it too high.</TD></TR></TABLE>
So... if he sets his VTEC to engage earlier it will change the nature of his VTEC cam lobe and give him better torque? Wow! Here I though VTEC was simply switching between two cam profiles each with their own power curve guess I was wrong...
Old Aug 2, 2003 | 09:45 AM
Casey's Avatar
Default Re: (preluda92)
Im not too worried about the tq curve. 131 ft lbs is good enough for me with what little mods i have, and it pulls like a freight train. Im going back to the track when i get the chance, might rain tonight but well see
Old Aug 2, 2003 | 10:11 AM
Chugger's Avatar
Default Re: (Casey)
sweet im glad your happy with the car
i do miss her
she was a moody bitch but ran her *** off
hehe
good luck man
yea drop the vtec to about 6200
lata
chris
watch those dogs on the backroads
Old Aug 2, 2003 | 10:30 AM
GSRswapandslow
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preluda92 &raquo;</TD></TR><TR><TD CLASS="quote">
So... if he sets his VTEC to engage earlier it will change the nature of his VTEC cam lobe and give him better torque? Wow! Here I though VTEC was simply switching between two cam profiles each with their own power curve guess I was wrong...</TD></TR></TABLE>
are you trying to be an *******?
but no, the vtec lobes are there to make power....not engage and then fall off. his is set REALLY high. If he set it lower...he'd have more RPM for vtec to work in and make the power it can.
Old Aug 2, 2003 | 12:54 PM
Rob Dizzle's Avatar
pretty good numbers
put a thinner head gasket and get a better header if you want to make more powa
Old Aug 2, 2003 | 02:30 PM
NA gs-R 05 C
Guest
Posts: n/a
those are some good #'s .
Old Aug 2, 2003 | 11:40 PM
yeer's Avatar
Default Re: My tuned GSR motor, 181.8/131.2. (NA gs-R 05 C)
good numbers.......post some time.
im guessing in around 2100lb car with 181whp, low 13s high 12s?? depending on your driving skills....
Old Aug 3, 2003 | 08:25 AM
Casey's Avatar
Default Re: My tuned GSR motor, 181.8/131.2. (yeer)
i went to the 1/8 mile, pulled 8.64 at 81 mph with a 1.76 60' but, my 2nd gear is fugged and takes a while to engauge(have to shift slow). Should be a mid 13. When i get an Si or ITR tranny well see low 13s high 12s
Old Aug 3, 2003 | 09:15 AM
igotyofire's Avatar
i cant see the dyno graph that well, cant tell which is which
Old Aug 3, 2003 | 10:29 AM
Casey's Avatar
Default Re: My tuned GSR motor, 181.8/131.2. (igotyofire)
both lines are about the same power
Old Aug 3, 2003 | 01:21 PM
WhiteEK's Avatar
Very nice
FYI- Race @ rockingham was cxl, last night
Old Aug 3, 2003 | 01:31 PM
falcongsr's Avatar
What is this crap?
i would definintely engage vtec a lot sooner. you will havemore torque sooner
Old Aug 3, 2003 | 01:36 PM
Casey's Avatar
I only had 150 bucks, and tuning is 100/hr. I was on the dyno for almost 2 hrs so I cant really complain, and im going back in a month or so once i get a hondata IM gasket and possibly icebox and larger injectors
Old Aug 3, 2003 | 05:41 PM
Mr Hammond's Avatar
a/k/a Jomo
Toda B's and C's love a higher VTEC engagement point. You can always do a test to find out, but I think tuning would play a role in that as well.
Old Aug 4, 2003 | 09:33 PM
B00ST2nR's Avatar
Default Re: My tuned GSR motor, 181.8/131.2. (Mr Milano)
sweet numbers... but if you run your car with the header on most of the time, you should tune it with the header on, so it will be tuned according to that...
Old Aug 5, 2003 | 03:51 AM
Casey's Avatar
Default Re: My tuned GSR motor, 181.8/131.2. (Skunk2nR)
i tuned it open header bc thats how i run at the strip. adding an exaust isnt going to change the tune much, besides making less power and running a little richer
Old Aug 5, 2003 | 04:00 AM
MARC P's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">i went to the 1/8 mile, pulled 8.64 at 81 mph with a 1.76 60' but, my 2nd gear is fugged and takes a while to engauge(have to shift slow). Should be a mid 13. When i get an Si or ITR tranny well see low 13s high 12s </TD></TR></TABLE>
With that HP/TQ you should go high 12's on some 13x22x8.
With similiar Numbers 179&135 in a 2100 CX I went 12.71.
Good luck and have fun.
Old Aug 5, 2003 | 09:42 PM
T4eg's Avatar
looks good
Old Aug 6, 2003 | 10:10 AM
00MRSi's Avatar
Default Re: My tuned GSR motor, 181.8/131.2. (BlueHatch00)
Nice #s..
Where did you tune your car?
