List of things to replace w/ motor & tranny out
Old Aug 1, 2003 | 08:42 PM
phil2000's Avatar
Default List of things to replace w/ motor & tranny out
I've got an H23 with about 110k miles on it that came out of a wrecked prelude. I'm going to drop it into my motor-less 93, and of course there's a bunch of things it's a good idea to replace while the motor and tranny are out. I've quickly brainstormed the list below, and I was wondering if y'all can give me input on things that should be added/deleted. Thanks-
-Replacement clutch kit
-Timing belt
-water pump
-all other belts (P/S, AC, alt, balance shaft)
-Front and rear main seals
-cam seals
-oil pan gasket
-valve cover gasket
-plugs
-timing belt tensioner assy?
-oil pump?
-main/rod bearings?
Old Aug 3, 2003 | 01:55 PM
phil2000's Avatar
Default Re: List of things to replace w/ motor & tranny out (phil2000)
allrighty - I guess I covered it then....
Old Aug 3, 2003 | 03:27 PM
CHK4TIX's Avatar
mclasser
Dec 25, 2013 11:41 PM
xxmastermindxx
Aug 4, 2006 09:35 AM
Fuster_Cluck
Feb 27, 2003 07:26 AM
deviant1
Dec 24, 2002 06:05 PM
