header clearance issue
Old Aug 1, 2003 | 05:05 PM
NA EJ1's Avatar
Default header clearance issue
i have a LS/VTEC, B18B1 block with a B16A2 head, i also have the Z10 main cap girdle which required me to use a GS-R oil pan...so now my DC 4-1 header for the B16A hits the oil pan and wont sit flush on the head.
Any ideas on wtf to do????
TIA
Old Aug 1, 2003 | 07:10 PM
Mohudsolo's Avatar
Default Re: header clearance issue (NA EJ1)
Does the B16 block have a shorter deck height than the B18B? My guess would be to use a TypeR header. That has room for the thicker pan and the B16 head is basically the same at the R head. Motors like yours are getting common, check suppliers for what they recommend.
Old Aug 1, 2003 | 07:34 PM
mmuller's Avatar
Mad Scientist
Default Re: header clearance issue (Mohudsolo)
yep b16 block is shorter, get a new header
Old Aug 2, 2003 | 03:59 PM
NA EJ1's Avatar
Default Re: header clearance issue (mmuller)
so what kind of header to cat-back issues will i face with a GS-R or Type R header?
i have a 94 civic coupe, i know that the B16 header is the perfect match up but i cant remember if you have to shorten or lengthen the exhaust piping to make an Integra header work.
Old Aug 2, 2003 | 08:01 PM
mmuller's Avatar
Mad Scientist
check this out:
93egSLEEPER
Dec 14, 2008 07:31 PM
slow91crx
29
Jun 12, 2006 01:53 PM
Lee_Delso
May 15, 2005 06:30 PM
lsvtec94
Aug 11, 2002 08:30 AM
eg6madness
Aug 7, 2002 08:24 PM
