Power needed to run 11's???
Guest
Posts: n/a
Just wondering if its possible...Set up is:
1993 Del sol (@ 2275 w/o driver)
JDM b16a
inline pro 3mm Headgasket
ARP studs
Braced Meng Manifold
t3/to4e 60 Trim .63 ar
3" DP and Exhaust
52lb injectors
Hondata s100
intank fuel pump
Jimfab traction bars
Stage 2 axles
Slicks
Gonna run 16psi on race gas, total weight of car with me is ~2450
JDM b16a
ARP studs
3" DP and Exhaust
52lb injectors
Hondata s100
intank fuel pump
Stage 2 axles
Slicks
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 »</TD></TR><TR><TD CLASS="quote">^^^^^^^^^^are you serious 1.6l gonna run 11s you better turn up the boost and that setup seems pretty stock internally ?</TD></TR></TABLE>
thats cuz it is
thats cuz it is
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmaxturbochic »</TD></TR><TR><TD CLASS="quote">have you had it dyno'd/tuned? if so what were your #'s?
what size slicks are you using? </TD></TR></TABLE>
No, just got it running...should be goin for tuning in a few weeks, As for the slicks, i was just gonna make a new post asking for opinions on size
you need about 350-375 whp at that weight to turn out 11's. we did 11.7 on a cx hatch we had with 22x8 slicks at 380whp on pump gas.that was first time to the track then the car was sold.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMatrix.com »</TD></TR><TR><TD CLASS="quote">you need about 350-375 whp at that weight to turn out 11's. we did 11.7 on a cx hatch we had with 22x8 slicks at 380whp on pump gas.that was first time to the track then the car was sold.</TD></TR></TABLE>
I would be happy with 11.999999
I also have a few things in mind to save a few more pounds...
Hmmm, not sure about the size of Del Sol calipers. You may need spacers. Shoot exospeedAMcrx (Wil) an IM, he should know. He can also hook you up with the rims/slicks.
when my car weighted 2460 and had 361 to the wheels, it went 11.38. this guy does not need near that much power just to run 11.90's. just look at pauls car along with many others.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">you need about 350-375 whp at that weight to turn out 11's. we did 11.7 on a cx hatch we had with 22x8 slicks at 380whp on pump gas.that was first time to the track then the car was sold.</TD></TR></TABLE>
He doesn't need any where near that amount of h.p to run 11's Hell I have a 00 B16A2 in my 93 hatch with an 80 shot direct port kit running 12.22 at ~110 mph pulling a 1.698 60'
