Valve Lash and Idle?
Old Aug 1, 2003 | 11:50 AM
Rhetoric's Avatar
Default Valve Lash and Idle?
Can an incorrect valve lash effect your idle?
Im trying to figure out why my idle drops from 900 to 600 and sometimes below that when I come to a complete stop.
I have Kenji's p28 and it seems to do it with his program more frequently than with my stock ecu. I've checked vac. hoses for any leaks, nothing. I've also been told that a lightweight flywheel could be why it drops? Any truth to that?
Anyhow, any suggestions would be great.
Old Aug 1, 2003 | 12:07 PM
GZR4DR's Avatar
Default Re: Valve Lash and Idle? (Rhetoric)
Ecu can greatly effect idle. If you just put it in and its doing it, the computer may correct itself over a short period of time and idle properly, however you could always open up the idle screw a little.
Old Aug 1, 2003 | 12:41 PM
Chris N's Avatar
do a valve adjustment
Old Aug 1, 2003 | 04:31 PM
GZR4DR's Avatar
Default Re: Valve Lash and Idle? (Chris N)
Oh and to add, if lash is to tight, it will idle low. If its to loose it will be loud and may have idle problems.
ViZ
Jan 16, 2011 02:05 PM
23nesnes
Sep 22, 2009 10:21 AM
BurgAccord95
Feb 16, 2009 06:30 PM
freddy_hung
Acura TL, RL & ZDX
Nov 25, 2005 03:07 PM
