need advise to install steering wheel
Old Aug 7, 2001 | 01:28 PM
ice-racer's Avatar
New User
Default need advise to install steering wheel
hi all, i'm going to put on the jdm non-srs to replace the stock wheel, looking for instruction/advise on how to go about it, mainly the safest way to take the factory steering wheel out, thanks!
97itr0474
Old Aug 7, 2001 | 10:44 PM
ice-racer's Avatar
New User
Default Re: need advise to install steering wheel (ice-racer)
c'mon ppl, help me!
Old Aug 8, 2001 | 02:47 AM
GZR4DR's Avatar
First unplug your battery. Then remove the side pieces that cover the star bolts for the airbag. Use the star hex key to remove the airbag. The rest is pretty straight forward. Dont forget to have the wheel lined up perfectly straight when you pull the steering whell off. Then just put the other wheel on straight as well.
One thing you have to do is remove the SRS controller deal behind the steering wheel as well. And i cant figure out how to properly wire up the horn. I think im going to have to wire it direct as i cant figure out which pin on the yellow loom is for the horn. I dont want to mess up my SRS when i do decide to put my stock wheel back on.
BTW i have the 97 ITR steering wheel also. Looks very nice in my car.
Old Aug 8, 2001 | 03:10 PM
ice-racer's Avatar
New User
thanx man! i like your si, that's what i used to drive before my itr, a 92 civic si with b16a. anyone else can help me with the wiring of the horn??
97itr0474
Old Aug 9, 2001 | 04:25 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
well, i personally used the little horn dinger thingy (ground) out of a 90 civic and set that up with wiring to my srs horn ground. that enabled me to get the horn to work in my 94 si with a jdm non-srs wheel. good luck...
crazyhouse2011
21
Apr 25, 2013 05:58 PM
civicDX2178
Jul 5, 2006 01:17 PM
Trippsol
Jun 13, 2006 06:38 PM
W O T
Sep 22, 2005 09:05 PM
mack
Nov 15, 2001 07:12 PM
