Would a zc crank pulley fit a d16a6 crank?
Old Aug 1, 2003 | 11:17 AM
VTgringo's Avatar
Default Would a zc crank pulley fit a d16a6 crank?
as the title states. my guess is that since i am running my d16a6 alternator and belt off the pulley it will work. I guess all d16 crank pulleys are the same. can anyone that has tried this back me up. thanks
Old Aug 1, 2003 | 12:33 PM
Ghostone's Avatar
Default Re: Would a zc crank pulley fit a d16a6 crank? (VTgringo)
well the timming marks will not be the same... but i am sure it will work
Old Aug 1, 2003 | 03:07 PM
VTgringo's Avatar
Default Re: Would a zc crank pulley fit a d16a6 crank? (Ghostone)
um.....all honda crank pulleys have 1 mark for TDC and then 3 other marks for 12, 14 and 16 deg ATDC. Any other thoughts
Old Aug 1, 2003 | 04:03 PM
VTgringo's Avatar
ttt
Old Aug 1, 2003 | 04:24 PM
quis23's Avatar
as long as they both have the same snout size!! some are 22mm are others are 24mm. what year is the zc pulley from?
Old Aug 1, 2003 | 04:28 PM
VTgringo's Avatar
Default Re: Would a zc crank pulley fit a d16a6 crank? (quis23)
it is a 1990 zc engine/pulley
Old Aug 1, 2003 | 05:06 PM
Project91CRX's Avatar
i'm using a D16a6 crank pulley on my DOHC ZC.. works fine for me. If i shouldnt be, please let me know now. thanks.
Modified by Project91CRX at 6:18 PM 8/1/2003
Old Aug 1, 2003 | 07:35 PM
quis23's Avatar
Default Re: Would a zc crank pulley fit a d16a6 crank? (Project91CRX)
the 90 zc should have a 24 mm snout with a harmonic balancer. on may last zc which was an 88; it had a 22m snout and no harmonic balancer.
Old Aug 1, 2003 | 08:54 PM
VTgringo's Avatar
could you tell me the snout size of crx's from 88-91. I am guessing that one of the years will be a direct match since someone has done it. thanks
Old Aug 2, 2003 | 06:34 AM
DJ_SaNdOz's Avatar
I am pretty sure that the 88-89 & 90-91 are the same size for both the A6 & the ZC
Old Aug 2, 2003 | 08:48 AM
quis23's Avatar
Default Re: Would a zc crank pulley fit a d16a6 crank? (DJ_SaNdOz)
no they different!! thats why i had to buy yours
i got some pics at work that i can post up monday to show you the differences
Old Aug 2, 2003 | 09:07 AM
VTgringo's Avatar
ok......i just took my 90 zc crank pulley off and it fit on the 91 d16a6 block. I'm not sure about the timing marks but the engine should be good to go
d15maverick
11
Feb 13, 2005 08:00 AM
StupidSlowRSX
May 5, 2004 06:58 PM
gregv
Feb 16, 2004 08:03 PM
quis23
Jul 14, 2003 10:40 AM
