grounding kits??
I made my own w/ 4 gauge wires & 24k terminals. It definitely improved my electrical system. My car is a 95 Accord. The existing grounds weren't exactly in the best shape, oxidized and stranded. All the lights are brighter and improved throttle response.
The performance increase depends on the quality of the existing grounds. If your car is new it might not show as much.
I bought one of those kits off ebay. Definatly a piece of ****. The wires are good and all, but the plate they make that goes on the battery sucks. The hole piece is aluminum to start off with, and one part wont get tight. So i tried to make it tight and the thing broke. POS. So i'm running the wires directly to my current battery connection now. Waste of money.
hey....i didnt experience throttle response (not sure how that would happen either).
my grounding points were.
original -> valve cover ->S2 Manifold -> VTEC soleniod ->Tranny ->stock ground point -> battery
yv
yv
the end product of a grouding kits is to insure a steady flow of electirical power..u won t feel an increase in pulling power..what ull feel is a quicker response, steadier idle and brighter everything
http://www.importtuner.com/tech/0212it_ppsuzuki/
I sell good quality grounding kits. E-mail me at Briansvtec@hotmail.com if you are interested. I'll hit you back up with some pictures/installs.
they don't so much hp, they do add or rather, regain a little low end torque from what I can see, but ya, the theory is sound, just not exactly certain what good they'd do on an accord or whatever....but all the same, it's cheap, go for it.
Nathan
Nathan
Install them in a series is the right way of doing it....so your right from like the body to the battery ground, to the manifold, to the block, to the tranny, then back to the body again.....so it is like a circle. Hope that helps. If you need a kit e-mail me at Briansvtec@hotmail.com
so in series huh.. example: battery to passenger shock tower - to intake manifold - to back of block - to driver side shock tower - to front head - to transmission - to battery negative.
am i getting it right?
ive seen pictures from the Sun Automotive site and it looks as if each wire goes back to the battery individually.
Kinda of like a circle.....ok to my knowlege it works like this....Body of car to the negative terminal of batter, to intake manifold, to tranny, to engine block or valve cover, back to the body of the car. You can do it in a varity of ways but it all should go back to the body of the car. Anyone can confirm this??? please do.
