Fuel leaking from Fuel Pressure Regulator/Gauge
I have a 1993 b16 in a 1997 Integra GSR, which here in the pics you can see the fuel mods but my problem here is a severe fuel leak where gas fills up the gauge face and then spills onto the supercharger and the block. I need this fixed ASAP!!! Thanks for any help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister »</TD></TR><TR><TD CLASS="quote">o-ring and proper torque spec</TD></TR></TABLE>
Proper Torque is a must, I couldnt get mine right for awhile....But he said it actually fills up the gauge face...Not just leaks around the threading...Could it still be the oring?
gmoore
gmoore
Yikes, I say pull the gauge for now. If you already have the FP set you shouldn't need it on all the time anyways.
I am inclined to think the actual gauge is broken.
I pulled the Gauge off and plugged it with a screw and teflon tape. I had one of my Honda Tech's take a look at it here at work they said it should be fine with a FPR installed. Yeah, the gauge was filling up with gas. Should I just buy another B&M Gauge or is there anything better out there on the market? BTW, like the setup there?
acmoc
Engine Management and Tuning
Apr 19, 2011 08:27 AM
cvc323
Oct 27, 2004 09:01 AM
