1990 B18A with more than bolt-ons...should I use chip + SAFC or go OBD1 + Hondata?
Old Aug 1, 2003 | 05:55 AM
haggar's Avatar
Default 1990 B18A with more than bolt-ons...should I use chip + SAFC or go OBD1 + Hondata?
My motor(well, I'm got the parts, its not assembled yet)
1990 B18A1
Crane #12 cams
P30 pistons with OEM 3 layer head gasket(11:1 comp)
PnP Head
Ported manifold
I/H/E
Stock injectors(sending thme to be cleaned/flow tested)
Really wanted to go with a Hondata system, which would be tuned specifically for my engine. But...they don't do an ODB0 system for the PR4...
So, then I was planning on running an Ericks racing chip, and a SAFC for final tuning.
Would if be better for me to get a OBD1 computer, convert my harness, and get an OBD1 Dizzy and 4 wire O2, and then run a Hondata system? I admit, I really like the idea of Hondata, rather than a generic chip.
Just wanted to get others opinions. I'm an Automotive/Electrical engineer, I'm very used to building wire harnesses, and soldering chips much smaller than the old DIP stuff in these ECUs, so none of the wiring work either way scares me, and I have to tools to do the work correctly.
Besides the distributor and O2 sensor, is there anything else than needs to be changed? Will my Injectors work with the current injector box?
Thanks,
Haggar
Old Aug 1, 2003 | 05:59 PM
Yosshaa's Avatar
safc should be fine.....
the obd1 with hondata would be nice for heavly modded engines all motor. it involves more then jus the harness and ecu there is the distributor and fuel injectors also. hope this helps
Old Aug 1, 2003 | 06:21 PM
Blown90hatcH's Avatar
Default Re: 1990 B18A with more than bolt-ons...should I use chip + SAFC or go OBD1 + Hondata? (haggar)
For a nice compression of 11:1....just spend the extra few hundred and get the hondata system. It is just nice to know that you didnt go the cheap route on your life insurance policy.
Old Aug 1, 2003 | 06:25 PM
90teg's Avatar
Default Re: (ambition)
i don't think you need the injectors. just the hardness, ecu, and distrutor. i'd go with the obd1 conversion if i was you. leaves room for upgrades later on.
Old Aug 1, 2003 | 06:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ambition &raquo;</TD></TR><TR><TD CLASS="quote">safc should be fine.....
the obd1 with hondata would be nice for heavly modded engines all motor. it involves more then jus the harness and ecu there is the distributor and fuel injectors also. hope this helps</TD></TR></TABLE>
Yeah, you do not have to run the OBD1 injectors. All you need is harness, 4 wire O2, distributor and ecu.
Jason
Old Aug 1, 2003 | 06:40 PM
90teg's Avatar
Default Re: (Blown90hatcH)
oh yeah forgot about the o2.
Old Aug 1, 2003 | 06:45 PM
jdmotorsports's Avatar
Default Re: (90teg)
or for the same price of all that you can run the zdyne gold ecu. its programamble.
Old Aug 1, 2003 | 06:55 PM
90teg's Avatar
Default Re: (jdmotorsports)
i thought about getting the zdyne, but i don't think with my setup it'll be good enough. so i'm gonna get a motec instead.
93delslow315
May 27, 2010 09:23 PM
R6E6I6D
Jul 24, 2005 06:08 AM
hotimportcrx
Jun 23, 2005 11:06 PM
CHRIS 1.8
16
Jul 5, 2003 04:00 PM
spettinger
Dec 9, 2002 07:08 AM
