Can someone please post a picture of their check valve setup?
Old Aug 1, 2003 | 12:15 AM
AcCO12D95's Avatar
Default Can someone please post a picture of their check valve setup?
I really need a picture on how it is used, because I've read some posts but still a bit confused on how to install it.
Thanks
Old Aug 1, 2003 | 06:13 AM
Poop111444's Avatar
Default Re: Can someone please post a picture of their check valve setup? (AcCO12D95)
http://www.cse.uconn.edu/~yele....html
Old Aug 1, 2003 | 08:03 AM
AcCO12D95's Avatar
Default Re: Can someone please post a picture of their check valve setup? (si_mekanik)
Yea, I read that one and saw the picture, but didn't see how it was installed onto the car? I see the hose and check valve on the picture, but one end says to intake and one says to map sensor, how do i connnect that hose the the map sensor?
Old Aug 1, 2003 | 11:48 AM
Pengo's Avatar
basically what you want to do is cut the vac line between the intake mani and map sensor. now put each cut end on the ends of the tee. on the open nipple of the tee run a small piece of vac line and attach the check valve. make sure u put it on the right way so that positive pressure is bled off. repeat as many times as necessary.
basically the picture you see is the vac lines, tees, and valves assembled but off the car. you would take off the vac line currently running from the im to map sensor and replace it with this one
h22sedan
Apr 3, 2007 09:30 AM
teggreen4
May 13, 2005 02:12 PM
88crxhfb16
Apr 29, 2005 07:30 AM
pelotudo
Aug 23, 2002 09:09 PM
technine
Aug 8, 2002 02:52 AM
