Stock Grounding points for 94' Accord
Old Jul 31, 2003 | 08:40 PM
one clean ride's Avatar
Default Stock Grounding points for 94' Accord
Trying to install my ground wire kit. Having trouble locating a few spots. I found the 2 wires leading from the negative terminal. And I found the 2 leading from the valve cover and motor mount. Are there more than 4 spots? any help is appreciated.
Old Jul 31, 2003 | 08:55 PM
integra dave's Avatar
Default Re: Stock Grounding points for 94' Accord (one clean ride)
what will the grounding kit do for you HP-wise or otherwise
Old Jul 31, 2003 | 08:58 PM
Default Re: Stock Grounding points for 94' Accord (integra dave)
from what i read, there is about a ~2 hp increase, better idle, brighter headlights. But there are many who will argue it does jack.
Its a cheap mod, why not.
Old Jul 31, 2003 | 09:06 PM
ForceXVII's Avatar
how much did u get it for? Im thinking of getting a hyper ground system which costs around $120. Hit me up
Old Jul 31, 2003 | 09:51 PM
GimpyAccord's Avatar
Default Re: Stock Grounding points for 94' Accord (ForceXVII)
120??? Yikes...
anyone ever heard of a 4 or 8 guage wire w/ring crimps from block -> chassis. costs a whopping 1.20.
Old Aug 3, 2003 | 02:04 PM
VRGNCD5's Avatar
Default Re: Stock Grounding points for 94' Accord (GimpyAccord)
I have. I bought about 10 feet of 8 guage cable w/clear casing, and some crimp on connectors, grand total, about $10.
And by the way, I have seen about 3 dyno sheets that prove the effectiveness of these ground kits
Old Aug 4, 2003 | 12:50 AM
jjj784's Avatar
just did part of mine today since i haven't got the new battery terminals. basically, i grounded the distributor, tb, and block. later, just upgrade the stock ground on the chassis and tranny. also upgrade the power terminal too. hope this helps. we did three ground kits today with my friend.
Old Aug 4, 2003 | 11:48 AM
Default Re: (jjj784)
Post some pics if any yall got them installed in the 5G accords.!
Old Aug 4, 2003 | 01:58 PM
mrnicolas's Avatar
anyone have a grounding diagram on a 4th gen for this?
Old Aug 4, 2003 | 02:19 PM
ApexiAccord's Avatar
Default Re: (mrnicolas)
points where you mite considering connecting to are
tranny
intake manifold
valve cover
chasis
and run it off the negative terminal post
also driverside mount
i made mine for $35 bux
used 10ft 8awg black monster cable wire for a sleeper look cuz i dont want to get clowned on hahaha. bought it at tweeter for 75cents a foot
distributor block from $15 to 20 bux
and 1 4awg wire that runs from the battery to the distribution block and out to the mounting points where i listed.
screw spending $100 for hyper ground
tell u the truth i didnt feel anything , but i was like wat the heck. its better then nothing at all. ill try to post pics up if i have time. because of the busy scedule im on.
Old Aug 4, 2003 | 10:25 PM
ForceXVII's Avatar
Default Re: (ApexiAccord)
do all ground wires need to attach to the - on battery?
Old Aug 6, 2003 | 07:56 PM
jjj784's Avatar
Default Re: (ForceXVII)
wow, i didn't know it would shrink that much. i guess tyr to copy and paste the url.
Old Aug 7, 2003 | 02:56 PM
not necessarly but it is good to connect to the battery. so that the battery can have extra ground or somt.
Old Aug 7, 2003 | 11:02 PM
ForceXVII's Avatar
Do you guys have any other close up pix?
hmgemperor2003
Jan 25, 2011 03:31 PM
STi-Thrill
Dec 6, 2009 02:46 PM
brian2903
Nov 4, 2003 06:43 AM
MidoriEK4
Jan 28, 2003 03:56 PM
One2chi
Jan 3, 2003 07:12 AM
