COilovers
Old Jul 31, 2003 | 07:59 PM
f1uxx's Avatar
Default COilovers
Anyone know of anywhere i can get coilovers with shocks AND struts , it seems no where does that , thanks
Old Jul 31, 2003 | 08:52 PM
p1ccoloz's Avatar
Default Re: COilovers (f1uxx)
http://www.optauto.com or http://www.wholehyper.com havent looked for awhile but maybe, just maybe....
Old Jul 31, 2003 | 09:06 PM
AWDxBOOST's Avatar
Default Re: COilovers (p1ccoloz)
optauto sucks...ive heard some not so great things.....
turboevolution is good...i think they sell coilovers, but im not sure
Old Jul 31, 2003 | 09:47 PM
laulau's Avatar
If you want a good package, neuspeed has their bilstein setup. The bilstein shocks have the 'grade 10'-metal look that are threaded for the spring perch(none of those slip on sleeves!). It comes with neuspeed racing springs. No pillow mounts included(must use stock ones). I have a set on a 94 4door ls and they feel REALLY good! I have not experimented with many setups, but I HAVE DONE my homework! So I will support my statement with others opinions(even other integra owners!). They say that it is the most comfortable integra they've ridden in that's been dropped(2.25+)! I'd have to say at high speeds, going 100+ feels like 70! And cornering is nearly flat (with the addition of certain tie bars). If these interest you, you may find them under "specials" at the integra section. I payed almost a grand with shipping (to Hawaii), so you can imagine that shipping to you will be considerably less. If not, I seen JIC for $600 or so. You can always go TEIN for about 1100 to 1300. I heard the JICs aren't so good and their known to blow.
94 4dr integra suspension
-bilstein/neuspeed coilover suspension
-neuspeed rear lower tie bar
-suspension techniques rear sway bar
-ingalls f/r camber kits
-cusco front strut bar
on the way!
-neuspeed front lower tie bar
-suspension techniques drop forks
*remember if your going to drop your car (a drop like mine), make sure you buy drop forks or skunks upper A arm camber kits. the bolt that sticks out of the factory A arm ball joint will hit the chassis and crack the paint. Just because the camber kit say it can go -3 degrees camber, don't believe it. Once the camber is off, the bolt will start to hit the chassis.
Old Jul 31, 2003 | 09:49 PM
laulau's Avatar
I think the front are struts and the back are shocks
Old Aug 1, 2003 | 12:46 AM
JDMturboLS's Avatar
Default Re: COilovers (laulau)
Re: COilovers (laulau)If you want a good package, neuspeed has their bilstein setup. The bilstein shocks have the 'grade 10'-metal look that are threaded for the spring perch(none of those slip on sleeves!). It comes with neuspeed racing springs. No pillow mounts included(must use stock ones). I have a set on a 94 4door ls and they feel REALLY good! I have not experimented with many setups, but I HAVE DONE my homework! So I will support my statement with others opinions(even other integra owners!). They say that it is the most comfortable integra they've ridden in that's been dropped(2.25+)! I'd have to say at high speeds, going 100+ feels like 70! And cornering is nearly flat (with the addition of certain tie bars). If these interest you, you may find them under "specials" at the integra section. I payed almost a grand with shipping (to Hawaii), so you can imagine that shipping to you will be considerably less. If not, I seen JIC for $600 or so. You can always go TEIN for about 1100 to 1300. I heard the JICs aren't so good and their known to blow.
yea dude thats kind like what i got on my car
<~~~ they ride good as hell plus they r not the bad of a price i payed alot more than that 4 mine
civic01coupe
Honda Civic (2001 - 2005)
Mar 7, 2008 02:34 PM
darithS
Apr 15, 2005 05:25 AM
llW0PllNefRex
23
Nov 18, 2003 06:57 PM
HybridMT
Sep 8, 2001 05:48 PM
GoLowDrew
Jul 12, 2001 09:09 AM
