ON Ebay NOW: 2001 Audi HID OEM Xenon Projectors !
http://cgi.ebay.com/ebaymotors...36476
Hey!
I have a pair for Audi A6 HID projectors for sale! These have the bulb holders and everything. This is an awesome pair of projectors that are ready to be retrofitted into your civic or integra or whatever for that OEM HID output!
This is SKAFIA's write-up on the OEM HID retrofit : http://www.skafia.com/itr/hid/
Hey!
Someone beat my bid! I bid $150 so anything over that you will win. Decided not to go HID anymore
Anyways, bump for these
i stopped when it went to $150. i was thinking about bidding again and i just checked it said it had ended early?? oh well.
i sold these outside of the auction right before it closed...
my C/F subs are still available and are going to run till it ends though
if anyone is interested in a set of OEM bi-xenon HID projectors i have some off a BMW for sale
These give the user a high/low beam HID setup
all you have to do is connect your high beam wiring to the 2 wires that come off the projectors and whenever you switch on your high beams, it automatically moves the sheild to high beam mode!!!
I will sell these for $150 straight up
pics will follow soon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurbothisLS »</TD></TR><TR><TD CLASS="quote">...if anyone is interested in a set of OEM bi-xenon HID projectors i have some off a BMW for sale
pics will follow soon</TD></TR></TABLE>
i don't get that?? will that work for the retrofit?
the bmw projectors will use a D2s bulb
the bMW projectors will also work for a retrofit just like the audi ones, the BMW bi-xenon i'm selling is just equipped with an automatic high-beam feature
when you turn on your high beams, you will get HID high beams
the only wires you hook up are the ones that power your regular high beams
all you have to do is cut and splice your high beam power and ground into the power and ground wires that come off of the BMW projectors
when you turn on your high beams, the motor in the projector, moves the shield inside the projector to give you high beam output!!
jumbronee
Jun 13, 2007 03:09 PM
