Tired of Scraping! and Hitting
Old Jul 31, 2003 | 04:58 PM
Puki
Guest
Posts: n/a
Default Tired of Scraping! and Hitting
I had my car lowered and it was a pain in the *** to drive.
Going over speed bumps at angles , etc.
Anyways my car is stock height on 15" with 50 series tires, fine right.
No! I still scrape and hit. My shocks need to replaced theyre almost dead.
I measured under my prelude has a little less thend 4 inches of clearance.
I believe its this link suspension thing down there.
Does anyone hit there also? Im stock height!
Old Jul 31, 2003 | 06:03 PM
Elkins911's Avatar
Default Re: Tired of Scraping! and Hitting (Puki)
sucks for you. im dropped an inch and a half and i dont hit at all. maybe you should just face the truth.... your a bad driver.
Old Jul 31, 2003 | 07:03 PM
rjr162's Avatar
just out of curiousity, which model uses the 15" 50 series, and wahts' the width? Just wondering, since the 5th gens use a 205/50R16
Old Jul 31, 2003 | 07:37 PM
Puki
Guest
Posts: n/a
Default Re: Tired of Scraping! and Hitting (rjr162)
15" Konigs and 50 Series and Falken Azenis.
Im not a bad driver.
At least I think Not.
I scrape when I pull out of the driveway, going into plaza over curbs.
Not the front its the bottom.
Old Jul 31, 2003 | 08:10 PM
blk97lude's Avatar
what is ur set up?
Old Jul 31, 2003 | 08:42 PM
Puki
Guest
Posts: n/a
Default Re: Tired of Scraping! and Hitting (blk97lude)
Stock 93 Prelude.....
15"Wheels on Azenis. I have 4 inches under front end of car...
I dunno. Am I riding lower then stock height?
My shocks are near dead Think Im riding bumpstops? I doubt theyre that dead.
I did have drop before...
Anyways, Noone else ever scrape at stock height?
Old Aug 1, 2003 | 06:18 AM
95h22a's Avatar
i slammed mine 4 inches just do as i do drive slow
Old Aug 1, 2003 | 08:27 AM
CHK4TIX's Avatar
Default Re: Tired of Scraping! and Hitting (95h22a)
i use to scrape all the time on my stock 15's but i got 17's and i dont bottom out as much.
Old Aug 1, 2003 | 10:02 AM
Greyout's Avatar
Default Re: Tired of Scraping! and Hitting (CHK4TIX)
you tires on 15's should be 205/55/15 or 215/50/15.
If they are 205/55/15, your car is sitting about 1/2" lower then stock.
Old Aug 1, 2003 | 10:29 AM
preluder's Avatar
Default Re: Tired of Scraping! and Hitting (Greyout)
just raise the car if its that much of a problem ya know. and check to make sure they arent busted . Stay away from the potholes know how to make clearance on bumps. Dont pay attention too much to the people honking behind you for slowing down if you bust up your car they dont care anyway so dont care about them and do your thang. Just avoid the bumps and drive sideways and dont sit so low or else youll get owned.
Kidloco51
Jun 25, 2008 05:17 PM
Cowiebunga
Oct 17, 2006 06:10 AM
fokai
Suspension & Brakes
Mar 9, 2006 01:54 AM
gospeedgo1
15
Jun 27, 2005 11:47 AM
civic702
Feb 21, 2005 01:39 PM
