Symptoms of cracked piston ring?
my compression is low in one of the cylinders....wondering if its a cracked piston ring or a sticking valve.....my motor runs strong and no problems have occurred....anyone know what the car would be doing if one of the rings were cracked?
He doesn't mean cracked, he means going bad.
his numbers are like 210-210-150-220 (or something very close)
I know that more than 15 psi difference isn't good. Also, his car smokes slightly. My suggestion is just get new rings (and ITR pistons, haha). Any others?
His car has been running slower than it used to (still fast though) at the track. -C
try a leak down test. maybe you have a burnt valve or worn rings.......i dont think cracked rings is very common at all.........
[Modified by non-VTEC, 5:32 PM 8/7/2001]
Oh and TypeC, you know if i got new pistons i'd go with ITR and not gsr
yeah, cracked rings aren't common, worn rings are. I'm thinkin burnt valve may be the case, I'll try checking the valve clearances for over tight valves. -C
jc2801
27
Aug 25, 2015 08:22 PM
natz20
Mar 15, 2008 09:55 PM
