need help pls... can a 96 d16 non fit in 88ef?
Old Jul 31, 2003 | 03:52 PM
fstblkcivic's Avatar
Default need help pls... can a 96 d16 non fit in 88ef?
well here is the thing... i know the engine is obd2 and all will the swap work? its just replacing the d15 out of the ef... engine is bad
Old Jul 31, 2003 | 04:10 PM
Fobtions's Avatar
Default Re: need help pls... can a 96 d16 non fit in 88ef? (fstblkcivic)
huh?
Old Jul 31, 2003 | 04:12 PM
1CiViC1's Avatar
yeah you can use that motor, just gotta use a ef tranny
Old Jul 31, 2003 | 05:16 PM
warrick's Avatar
"Q: Can someone clarify in detail what I need to do for an '88 CRX??
Can I retain my '88 tranny? Will the difference in splines be a problem?
Can I use an upgraded '92-'95 clutch, plate, and flywheel on my '88?
A #1: (by [Ed])
The 88 splines are different, you'll need an 89-91 tranny if you want to use the 89-on flywheel/clutch. Or swap the 88 flywheel to the new motor."
http://hybrid2.honda-perf.org/tech/sohcvtec.html updates on the bottom
user 98292739
May 6, 2007 12:32 PM
n3h3bkau
15
Apr 10, 2007 11:23 AM
gutted-dx
10
Apr 19, 2005 04:15 PM
nuc79
Feb 1, 2004 08:21 PM
CimorelliCRX
16
Dec 12, 2002 05:13 AM
