wtf is this thing on my B18A?
Old Jul 31, 2003 | 03:36 PM
turbohf's Avatar
Default wtf is this thing on my B18A?
we are talking about the one circled in RED...
anyone know what it is? what is does? is it needed? blah, blah, blah...
this is on my 1990 B18A1 from a Integra w/auto tranny (use to anyway)...
Old Jul 31, 2003 | 03:38 PM
turbohf's Avatar
Default Re: wtf is this thing on my B18A? (turbohf)
oh I DONT NEED TO TAKE/PASS EMISSIONS...
Old Jul 31, 2003 | 03:52 PM
.ShawnD.'s Avatar
i have that same 2 things on my b16 .. i was ask by another HT member the other week at a meet ... if my motor was an automatic .. he said those things had somthing to do with being an automatic .. then some other guy said no ?? so i would also like to know
Old Jul 31, 2003 | 03:55 PM
johnzm's Avatar
Default Re: (.:s h a w n D:.)
n/m
Old Jul 31, 2003 | 04:06 PM
silverCRXTC's Avatar
Default Re: (johnzm)
i had those on my b16a,it just some vacuum line, i removed it with my skunk2 manifold and never seen them hooked up, i believe it did have some think with an auto tranny, because my motor was purchase without a tranny (maybe an auto) and every trann combo ive seen lack that bottom line
Old Jul 31, 2003 | 04:35 PM
Charlie Moua's Avatar
post or link it to the tech form. they will know for sure.
Old Jul 31, 2003 | 04:40 PM
pokemon's Avatar
cruise control
Old Jul 31, 2003 | 04:55 PM
bagged89hatch's Avatar
Default Re: (pokemon)
that is a up
Old Jul 31, 2003 | 04:57 PM
misfithamster's Avatar
Default Re: (bagged89hatch)
that would suck to get an auto motor
Old Jul 31, 2003 | 05:12 PM
nevin's Avatar
why?
Old Jul 31, 2003 | 05:26 PM
buzboy's Avatar
Default I know what it is
Ok I'll clear this up. That my friends is a booster valve. It allows extra air to enter the engine during cranking, so the engine will start easier. When there is vacuum at the vacuum fitting, the valve closes.
Old Jul 31, 2003 | 05:49 PM
Shawn C's Avatar
In The Garage
hey shawnD, i'm the guy you were talking to at the meet. (nice rex by the way). i don't know about the "booster valve" thing, that sounds kind of like something made-up to me. thats what the EACV (or IACV on newer cars) is for.
i'm pretty sure it's for an auto tranny, since the USDM IMs had the same flange, just un-tapped for that valve/actuator. find someone with an auto DA, and see what the thing is hooked up to. then let us know...
-Shawn C
Old Jul 31, 2003 | 06:12 PM
90Zcrx's Avatar
Default Re: (misfithamster)
Actually if you're going to build it, I'd RATHER have an automatic motor. At least that way I'd know it hasn't been overreved or heavyily downshifted. Duh.
Old Jul 31, 2003 | 06:26 PM
Josh717's Avatar
On the b16s it more then likely comes from the integra xsi, it came with that vacuum port thing, and this also means you have a 168hp first gen b16
Old Jul 31, 2003 | 06:45 PM
Default Re: (90Zcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90Zcrx &raquo;</TD></TR><TR><TD CLASS="quote">Actually if you're going to build it, I'd RATHER have an automatic motor. At least that way I'd know it hasn't been overreved or heavyily downshifted. Duh.</TD></TR></TABLE>
ahh yes, how true, good thinking man. now are the cams the only thing that would need to be changed out, cause theyre different on autos right?
Old Jul 31, 2003 | 07:06 PM
turbohf's Avatar
auto and manual B18A are the same just have an EGR, flexplate, and maybe whatever that little gay thing is...
and yes thats why i have a motor from an automatic car, its un-molested...
Old Jul 31, 2003 | 08:17 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
Default Re: (turbohf)
My B16 has the same thing... it's from an Integra Xsi... but it has an S1... that's weird... I've got it plugged though... I never thought anything else about it??
Mine also hod an extra vacuum line at the speedo cable, and it had an AC compressor attatched to it, along with another funky mount...
Can someone say for sure what it is??? And I'm liking the prospect of having 168hp....
Anyone??
Old Jul 31, 2003 | 09:36 PM
krazyDOHC's Avatar
Default Re: (VashTheStampede)
ttt....i want to know exactly what that is
Old Jul 31, 2003 | 10:03 PM
jisu009's Avatar
Default Re: (krazySOHC)
dashpot
Old Jul 31, 2003 | 10:05 PM
turbohf's Avatar
im done caring what it is or what its for, i took it off. now i just need to plug the hole with something (the car will be turbo'ed later so it needs to be tight). i took that stupid metal vacuum hose **** off and plugged the two extra bigger ports (one went to the think that is circled). now i have two vacuum ports on the back, the perfect spots for my boost gauge and MAP (will be a GM 2-3bar)...
Old Jul 31, 2003 | 10:46 PM
Rex_Dragon's Avatar
Sup People,
Can you just take all this stuff off? I am wanting too put a strut bar on and it interfears with all this crap.
Old Jul 31, 2003 | 11:03 PM
c for sea's Avatar
that plug wire cover is funky..
Old Jul 31, 2003 | 11:11 PM
91civicDXdude's Avatar
the one guy was right. Its an "air boost valve" it allows more air to enter the engine at certain times, controlled by vacuum. The similar looking thing is the dashpot, it is controlled by vacuum and its purpose is to control how quick the throttle slams shut so as the car will run smoother on deceleration.
turbohf's Avatar
Default Re: (Rex_Dragon)
well i just dont want that **** there, dont have to take emssions, and think that stuff looks like ***. i am leaving the one on the T-body cuz i have disconected the one on my ZC before and it idled like **** (think it was just on warmup). i also dont have those purge valves or whatever hooked up (the 'box' on the firewall, i threw it all in the 'extra parts bin'). im just wanting a cleaner look to the engine compartment...
Old Jul 31, 2003 | 11:20 PM
Rex_Dragon's Avatar
Default Re: (c for sea)
The wire cover is jel-coted.
I got a freind that works at a boat manufacturing plant and we was just messn around.
Was thinkin about doin all the plastic materials under hood.
Alarm,Fuse Cover, Battery,Brake Fluid Res.
