Gears wont engage
Old Jul 31, 2003 | 02:34 PM
02 coupe's Avatar
Default Gears wont engage
My friend has a 99 prelude 5 speed and his 1, 2nd, and 3rd gear wont go in, also reverse. It was driving fine then we stopped off @ a Mc'Ds and when we started it back up the gears would not engage. what could be the prblm?
Old Jul 31, 2003 | 05:25 PM
PrecisionH23a's Avatar
Default Re: Gears wont engage (02 coupe)
Did this happen all of a sudden or has it been an ongoing problem?
If its ongoing, it is most likely the synchro's going to hell.
It it happened all of a sudden, check the shift linkages that go to the tranny and look for anything not normal.
Also, Does he run a short shifter by any chance? If so, I would inspect the installation of it to make sure anything didnt become loose.
Old Jul 31, 2003 | 05:41 PM
4bidden's Avatar
Default Re: Gears wont engage (GudeH23a)
Will it shift when the car is off?
Old Jul 31, 2003 | 06:05 PM
Prelude Vtec 23's Avatar
Default Re: Gears wont engage (4bidden)
Try checking your brake fluid too, if thats low sometimes, it wont go in either.
Old Jul 31, 2003 | 06:12 PM
PetroGuyX's Avatar
the brake fluid in the clutch resivior that is, is there still pressure in his clutch?
Old Jul 31, 2003 | 11:21 PM
02 coupe's Avatar
Default Re: (PetroGuyX)
figured it out... it was bad clutch fluid. thanks for the feedback.
tstchatch
16
May 20, 2010 10:25 AM
civic99585
Jan 27, 2009 11:14 PM
diewX3
Mar 20, 2005 02:11 PM
danman3323
Feb 25, 2005 06:08 PM
SnkyPY
Dec 11, 2003 09:16 AM
