D series injectors will not get enough "power" on a B series swap?
Old Jul 31, 2003 | 01:12 PM
Nameless RB26's Avatar
Default D series injectors will not get enough "power" on a B series swap?
We have a B series engine with D series injectors just to get it running.
The car was not getting power to the fuel pump earlier. That problem is fixed and the tech says the injectors are not getting enough power now.
I'm suspecting this is because they are D series?
Could it be?? Are they that different?
Old Jul 31, 2003 | 01:47 PM
scottcrxsi's Avatar
Default Re: D series injectors will not get enough "power" on a B series swap? (Nameless EJ6)
which D......which B? Years (ODB?)
Old Jul 31, 2003 | 02:03 PM
jumpmann23's Avatar
From: Your really lame if you dock my points, WA, 98033
Default Re: D series injectors will not get enough "power" on a B series swap? (scottcrxsi)
obd2 d series injectors
Old Jul 31, 2003 | 02:10 PM
chet's Avatar
Default Re: D series injectors will not get enough "power" on a B series swap? (RuthlessEj6)
all b/d series run 240cc injectors
Old Jul 31, 2003 | 02:57 PM
Default Re: D series injectors will not get enough "power" on a B series swap? (chet)
hmm.
Then wtf.
Any ideas why this tech would say that?
Old Jul 31, 2003 | 03:15 PM
scottcrxsi's Avatar
what year is the B engine/ECU?
If it's a B16 89-91 JDM it will be looking for a 2 ohm coil (OBD0) and resistor box to keep the current (read power) in check
Old Jul 31, 2003 | 04:09 PM
jumpmann23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scottcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">what year is the B engine/ECU?
If it's a B16 89-91 JDM it will be looking for a 2 ohm coil (OBD0) and resistor box to keep the current (read power) in check</TD></TR></TABLE>
the engine is an ls/vtec b18a block and b16a first gen head in a 96 civic hatch dx. using the dx harness and obd2 dx injectors and obd2 distributor.
ALL MOTOR EM2
Dec 30, 2016 07:23 AM
dc4teg95
Feb 11, 2010 05:23 PM
EK79
May 27, 2007 01:48 PM
AMZ GS-R
Jun 14, 2004 12:22 AM
Mucackus
Apr 24, 2002 05:29 AM
