2003 si Passenger side mirror install questions
My passenger side mirror came off in a little accident
. I need some help with the install. Can anyone knowledgeable tell me how to remove the interior door panel so i can get to the mirror's power plug? I don't want to go destroying my panels trying to get them open
. Anyone with a service manual would be greatly appreciated
Thanks in advance
. Thanks in advance
Its just held on by clips... but I would advise the only way you should get it off is using and door panel remover tool so you dont break any clips... takes about a min to get off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stupendous Man »</TD></TR><TR><TD CLASS="quote">so is it just one big piece? I'm realy clueless as how to approach the whole thing
yes your door panel is just one peice... all its held by is clips that takes a min to get off if you have the right tools.
</TD></TR></TABLE>yes your door panel is just one peice... all its held by is clips that takes a min to get off if you have the right tools.
i recently took off my door panels to install speakers.
it's actually pretty easy, first you have to remove your tweeters, and the door panel there are three screws you have to remove. check this out http://www.k-series.com/tech_d...STALL
good luck ....
good luck ....
