Hondata IM gasket installation tips
Im about to install this on my lude. Do i have to take out the whole manifold or can i just take it apart and pull out the old manifold and put in the new one without taking it all out?
How hard was it removing the lower IM? Did you use gasket remover to take off the old gasket? I'm tackling this in a couple of weeks. I'm thinking it should take about 3-4 hours.
Keith
Keith
moter out here also... i drilled a hole in it, so it wouldn't block off the egr there, i blocked it off right at the egr itself, incase i need to have it fuctional i would not have to pull the itm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egCivicDon »</TD></TR><TR><TD CLASS="quote">here is a dyno graph of the NextGear gaskets.
http://home.comcast.net/~nextgear/</TD></TR></TABLE>
negative
negative
so the gasket blocks off the egr??
how can blocking the egr benefit you?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 »</TD></TR><TR><TD CLASS="quote">moter out here also... i drilled a hole in it, so it wouldn't block off the egr there, i blocked it off right at the egr itself, incase i need to have it fuctional i would not have to pull the itm.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR »</TD></TR><TR><TD CLASS="quote">so the gasket blocks off the egr??
how can blocking the egr benefit you?</TD></TR></TABLE>
The EGR (exhaust gas recurulation) pulls hot exhaust into the intake making the intake charge hotter defeating the purpose of the gasket. It does that to reduce emissions and help prevent detonation to some extent.
sorry to bring it back from the dead haha... but yah, through searching i've read mixed replies about needing to block the egr off and what not. So is it true that if you don't block off the egr valve that it'll deem the hondata IM gasket pointless?
