Advantage of divided exhaust housing?
Old Jul 31, 2003 | 09:36 AM
Bnjmn's Avatar
Default Advantage of divided exhaust housing?
Is there any advantage to a divided exhaust housing on the turbo for a B18C engine? Could anything be incorporated into the turbo manifold to take advantage of the divided housing?
Thanks
Ben
Old Jul 31, 2003 | 09:40 AM
mike1114's Avatar
Default Re: Advantage of divided exhaust housing? (Bnjmn)
My knowledge is limited but the divided housing is better because on a 4 cylinder 2 cylinders fire then the other two, the divided housing seperates the pulses and makes their path slightly smaller to make the turbo spool up faster.
Old Jul 31, 2003 | 09:44 AM
kommon_sense's Avatar
Default Re: Advantage of divided exhaust housing? (mike1114)
If that is the case, then seems like you would have to have a turbo manifold designed like a 4-2-1 header to take advantage of the divided housing.
Old Jul 31, 2003 | 09:47 AM
Bnjmn's Avatar
Default Re: Advantage of divided exhaust housing? (kommon_sense)
That'll make wastegate plumbing a pain in the butt. Anyone else?
Old Jul 31, 2003 | 03:34 PM
Bnjmn's Avatar
Default Re: Advantage of divided turbo exhaust housing? (Bnjmn)
up.....
Old Jul 31, 2003 | 04:08 PM
rOby's Avatar
u mean tangential? it basically places the shaft directly inline w/ the flange, instead of somewhere lower like most our turbos. most turbos have a ppath they follow, the air enters and is guided to the shaft. the tangentials ive seen place the shaft directly infront of the flange..
Old Jul 31, 2003 | 04:17 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bnjmn &raquo;</TD></TR><TR><TD CLASS="quote">That'll make wastegate plumbing a pain in the butt. Anyone else?</TD></TR></TABLE>
Yah, i found that out the hard way. The turbo and manifold i have are divided housing. When i first got to the dyno, from 7200rpms to 9200rpms, the boost was spiking from 17psi to 26psi! heres what i did.
Before:
After:
Turbo Dandees manifold, Same design, same problems that were had on Kenny Trans racecar with this manifold
Old Jul 31, 2003 | 04:43 PM
Bnjmn's Avatar
Default Re: Advantage of divided turbo exhaust housing? (rOby)
Here is a pic of my new baby-
Thanks very much for that pic of the manifold...it'll help a bit.
Old Jul 31, 2003 | 06:06 PM
Bnjmn's Avatar
Default Re: Advantage of divided exhaust housing? (SIXTYdashONE)
Does that manifold use a divided flange as well? Anyone sell those or will that have to be custom? Do you have any pics of what the inside of the collector on the manifold looks like?
Apparently divided manifolds/housings are all the rage on RX-7s and Supras but haven't trickled down much to Hondas. From what I've found it is a massive waste not to use a divided manifold and flange when you have a divided turbo housing.
The divided housing is supposed to help with spool up since it seperates the engine's exhaust pulses and keeps them from "competing" with each other. Feel free to correct me if I'm wrong.
Thanks
Ben
Modified by Bnjmn at 10:16 PM 7/31/2003
Old Jul 31, 2003 | 06:09 PM
Arturbo's Avatar
Better than steak
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bnjmn &raquo;</TD></TR><TR><TD CLASS="quote">Does that manifold use a divided flange as well? Anyone sell those or will that have to be custom? Do you have any pics of what the inside of the collector on the manifold looks like?
Thanks
Ben</TD></TR></TABLE>]
Full-race uses a divided collector which is just sweet and works really well. I wont post pics with out geoff's permission.
Old Jul 31, 2003 | 06:55 PM
Boostfed's Avatar
New User
Default Re: Advantage of divided exhaust housing? (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">]
Full-race uses a divided collector which is just sweet and works really well. I wont post pics with out geoff's permission.</TD></TR></TABLE>
Actually Art he doesn't make them with divided housings unless the customer insists on it, I was sent a divided housing turbo but we all wanted the undivided, when I talked to Geoff he didn't believe in the divided housings and neither did tony1. I tried to get a few opinions. Garrett stated that knifedging the turbine housing if it is divided will act the same as an undivided.
Old Jul 31, 2003 | 06:58 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Advantage of divided exhaust housing? (Boostfed)
I said collector, not housing.
Old Jul 31, 2003 | 07:00 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">I said collector, not housing.</TD></TR></TABLE>
Neither! He made that collector on the site since the customer insisted.
Old Jul 31, 2003 | 07:02 PM
Arturbo's Avatar
Better than steak
25 Year Member
Race manifold, not street.
Old Jul 31, 2003 | 07:03 PM
Full-Race Geoff's Avatar
there is no advantage on our cars to running a divided housing, there is only a disadvantage.
We have a proprietary collector design that works better than either style, or combination of the two. no pics for a little while.
Old Jul 31, 2003 | 07:06 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Advantage of divided exhaust housing? (FFgeoff)
Dont worry geoff, I didnt have any pics anyway.
Old Jul 31, 2003 | 08:08 PM
tony1's Avatar
I do
Old Jul 31, 2003 | 08:52 PM
bambooluv's Avatar
Default Re: Advantage of divided exhaust housing? (tony1)
I hope this will work good for me.-pdang
Old Jul 31, 2003 | 08:54 PM
youngkow's Avatar
So, is there any negative effects of using a divided turbo with a non divided manifold? i.e. inline pro mani?
Old Jul 31, 2003 | 09:42 PM
HT's Biggest Loser
The divided housing is supposed to help with spool up since it seperates the engine's exhaust pulses and keeps them from "competing" with each other. Feel free to correct me if I'm wrong.Modified by Bnjmn at 10:16 PM 7/31/2003</TD></TR></TABLE>
YES, my manifold AND turbo is divided. With all honesty, i dont really know the advantages and disadvanteges of it (esp. on a honda), Geoff, care to chime in?
Old Jul 31, 2003 | 09:48 PM
bambooluv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE &raquo;</TD></TR><TR><TD CLASS="quote">
YES, my manifold AND turbo is divided. With all honesty, i dont really know the advantages and disadvanteges of it (esp. on a honda), Geoff, care to chime in? </TD></TR></TABLE>
Old Aug 1, 2003 | 06:36 AM
Bnjmn's Avatar
What is the disadvantage to a divided housing? When is it an advantage?
Old Aug 1, 2003 | 02:24 PM
Bnjmn's Avatar
ups....
Old Aug 1, 2003 | 03:26 PM
Enzo-Racing's Avatar
I love divided housings! And yes there is benefits especially on smaller motors.
I'll post pics later tonite of a header we did for a customer.
Old Aug 1, 2003 | 04:58 PM
Default Re: Advantage of divided exhaust housing? (Header Tech)
All turbo headers should always take advantage of the exhaust pulses. In a undivided design you should always run them sequential(1-3-4-2).
With a divided housing, and a properly designed header, You will notice excellent throttle response and almost non-existent turbo lag. In addition it allows you to use large turbos on very small engines. F1 cars of the engines were 1.5L making over 1200hp. (ex.. Hart, Bmw, Zakspeed)
With the divided housing you should group cylinders 1&4 into a 2 into 1 collector and cylinders 2&3 in another 2 into 1.
Wastegate needs to be plumbed from each group!!!
I like to consider it free power, take advantage of it and it will be a totally different machine, you get the benefit of using a low restriction/pressure turbine combination while retaining the instant response offered by harnesing the power of exhaust pulses to full effect
Take a look at one of ours.
Modified by Header Tech at 9:38 PM 8/1/2003
