How do you know if your shocks blew out?
Old Aug 6, 2001 | 11:00 PM
d0nkeyxPunch's Avatar
Banned
Default How do you know if your shocks blew out?
I was just wondering how you know if your aftermarket shocks are blown? I have no idea. I wanted to know what the signs are of a blown shocks. Also how do you blow them out anyways?
Old Aug 7, 2001 | 01:30 AM
raene's Avatar
Default Re: How do you know if your shocks blew out? (FastxCivic)
It's easy to tell if your shocks are blown. If you go over a bump and your car goes up and down and up and down and up and... that means your shocks are dead. A normal car should bounce maybe once, twice.
Old Aug 7, 2001 | 03:31 AM
MysteryWagon's Avatar
Default Re: How do you know if your shocks blew out? (raeneshadow)
they also make noises. weird ones. like there is a bird in the back.
Old Aug 7, 2001 | 07:26 AM
fsp31's Avatar
Default Re: How do you know if your shocks blew out? (ShaggenWaggon)
Look for shock oil on the ground where you normally park. Also, there will probably be oil all over the shock itself (unless they're gas struts, then I dunno). The best way to tell though, is to remove the shock and see how much resistence there is on the plunger. Blown shocks that I've worked on could be moved up and down about as easily as a bicycle pump...
Jon777
Suspension & Brakes
10
May 6, 2011 09:15 AM
JDM00SI
Sep 15, 2004 11:46 AM
PAID-$$$
Aug 24, 2004 10:38 AM
