does the iab wire go to a ground or a 12v source
Old Jul 30, 2003 | 08:39 PM
u2civic1's Avatar
Default does the iab wire go to a ground or a 12v source
does the iab wire go to a ground or a 12v source??
keep getting mixed answers
for a obd2a
Old Jul 30, 2003 | 09:43 PM
u2civic1's Avatar
Default Re: does the iab wire go to a ground or a 12v source (u2civic1)
anyone
Old Jul 31, 2003 | 12:38 AM
MPower332TI's Avatar
There are 2 wires. One goes straight to the ecu and the other goes to a 12v source.
Old Jul 31, 2003 | 03:15 AM
kenji's Avatar
Default Re: does the iab wire go to a ground or a 12v source (jDmDxTuRd)
Actually, for OBD2v1 (OBD2a) the red/blu (OBD2 engine harness) or the pink/blu (OBD1 engine harness) wire goes to the ECU (A26 - OBD2v1, A17 - OBD1, B16 -OBD2v2). Those pin locations are from memory. I don't have my notes or Helm's manuals handy. If I am incorrect on any of them please correct me.
If you are using an OBD2 ECU the other wire goes to ground. If you are using an OBD1 ECU the other wire goes to a 12v switched source. It all depends on which ECU you are using.
OBD2 uses a positive trigger to activate the IAB. OBD1 uses a negative trigger to activate the IAB.
Good luck.
-kenji
Old Jul 31, 2003 | 10:35 AM
u2civic1's Avatar
Default Re: does the iab wire go to a ground or a 12v source (kenji)
so its a ground for sure?
Old Jul 31, 2003 | 07:41 PM
u2civic1's Avatar
i tryed ground it but it stills stay closed
should i try a 12v source
if i try a 12v would it blow my ecu
Old Jul 31, 2003 | 09:30 PM
u2civic1's Avatar
hey can i pay someone to plug this in for me correctly
all the wires are there all i need is someone to plug them in to the ecu and plug the other wire in to a ground or 12v
im located in orange county , CA
email me at u2lover@aol.com
Old Aug 1, 2003 | 01:11 PM
u2civic1's Avatar
no one wants to help
shahriar35
Jan 14, 2012 01:09 PM
Greg456
Apr 22, 2004 07:49 PM
tiresmoke
Apr 19, 2004 05:12 AM
junglerunna
Apr 10, 2003 04:11 AM
dtailspls
Mar 11, 2003 07:25 PM
