What can cause brake pedal to go low ?
Old Jul 30, 2003 | 07:50 PM
96IntegraLS4DR's Avatar
Default What can cause brake pedal to go low ?
I bled my brake twice and the second time, no more air came out.
Still brake pedal goes really low to fully stop the car.
Thanks for your help
Old Jul 30, 2003 | 07:53 PM
stnwag0n's Avatar
Default Re: What can cause brake pedal to go low ? (96IntegraLS4DR)
bleed it more?
Old Jul 30, 2003 | 07:55 PM
DB8_TEG's Avatar
check and see if your brake master cylinder is leaking against the firewall.
Old Jul 30, 2003 | 08:12 PM
Fuuma0083's Avatar
Default Re: What can cause brake pedal to go low ? (DB8_TEG)
if you have to pump the brakes to achieve regular braking, it might be your MC seal going out. Hit the brakes do they keeping going down to the floor?
If not might just need to bleed your brakes.
Old Jul 30, 2003 | 08:26 PM
Tweakmeister's Avatar
Default Re: What can cause brake pedal to go low ? (Fuuma0083)
try an MC Brace
Old Jul 30, 2003 | 10:15 PM
HapaHaole's Avatar
Default Re: What can cause brake pedal to go low ? (Tweakmeister)
check the pads. if there is huge pad taper (pads not wearing flat) then that may be a cause of the pistons to knock back quite a bit. you will get this more with slightly mroe agressive driving style vs every day driving.
Old Jul 30, 2003 | 11:34 PM
DRFlickner's Avatar
Default Re: What can cause brake pedal to go low ? (SBE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SBE &raquo;</TD></TR><TR><TD CLASS="quote">check the pads. if there is huge pad taper (pads not wearing flat) then that may be a cause of the pistons to knock back quite a bit. you will get this more with slightly mroe agressive driving style vs every day driving.</TD></TR></TABLE>
I agree, check the pads.
Old Jul 31, 2003 | 04:24 AM
JimBlake's Avatar
Default Re: What can cause brake pedal to go low ? (turb0accrd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turb0accrd &raquo;</TD></TR><TR><TD CLASS="quote">bleed it more?</TD></TR></TABLE>
When I've sucked air into the brakes, it usually has bubbles right away, then I bleed & bleed for a long time without bubbles; then finally more bubbles come out. I bet you just didn't bleed enough - besides, thats the easiest thing to check. How much fluid did you bleed out at each wheel?
Old Jul 31, 2003 | 05:09 AM
Default Re: What can cause brake pedal to go low ? (JimBlake)
OK, I'll do more brake bleeding this weekend before considering brake MC replacement.
Thanks to all brake gurus out there for your help.
Old Jul 31, 2003 | 12:41 PM
HapaHaole's Avatar
one more thing to do when you are bleeding is to take a dead blow hammer or a rubber red neck mullet-i mean mallet and tap the caliper. like soda, bubbles can get stuck to the walls of the caliper and such.
now go drink a soda and think about it
Old Jul 31, 2003 | 12:47 PM
LS stretch's Avatar
master cylinder is probally shot
Kennyjai
Nov 28, 2012 12:00 PM
macmac89
Dec 28, 2010 09:12 AM
chris3k
Nov 2, 2008 08:05 PM
HATCHingMN
Feb 24, 2004 09:17 PM
d0nkeyxPunch
Oct 26, 2001 09:28 AM
