deck plate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10s_ALLMotor »</TD></TR><TR><TD CLASS="quote">dont waste your time or $$ on putting a deckplate on a B16 block.</TD></TR></TABLE>
well..i would rather DeckPlate is B16 block then a B18A/B block IF i were changing the Crank as well..because then you wouldnt have to worry about an oil line for the head (sorry Tech43, your lines are the best but i rather not deal with any lines at all
I'd rather deckplate a b16 then a b18 block as well. Golden eagle will give you a 1" deckplate instead of a 5/8", so that your motor will have the same deckhieght as a deckplated b18a...
or you can get a b18a block and run a b16 sized deckplate! If i want that, I have one for sale!
anothersickhatch
Jun 26, 2004 01:02 PM
2:
