D-series turbo & A/C possible?
Old Jul 30, 2003 | 01:04 PM
Rydaddy's Avatar
Default D-series turbo & A/C possible?
Im looking at piecing together a little turbo kit for my 97 coupe.....my fat hoe needs a little boost! Ive noticed that when using the HF/cx manifold that A/C isnt possible....how about with kits? Do the Drag/Greddy/Apex'i kits allow for the use of A/C? I want to keep the budget semi-low (not dropping 2 g's for a kit), but I want A/C!!
Old Jul 30, 2003 | 01:48 PM
Pengo's Avatar
Default Re: D-series turbo & A/C possible? (Rydaddy)
greddy kit retains ac
Old Jul 30, 2003 | 02:49 PM
Rydaddy's Avatar
Default Re: D-series turbo & A/C possible? (Pengo)
So am I correct when I assume that A/C cant be used with the HF manifold, no matter how you hook up an adapter plate?
Old Jul 30, 2003 | 03:19 PM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pengo &raquo;</TD></TR><TR><TD CLASS="quote">greddy kit retains ac</TD></TR></TABLE>
Yep, same as the A'PEXi kit and Edelbrock kit, I believe. Don't know about the HF manifold setup, though.
Old Jul 30, 2003 | 05:00 PM
stackz's Avatar
at the jetties fishin'
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rydaddy &raquo;</TD></TR><TR><TD CLASS="quote">So am I correct when I assume that A/C cant be used with the HF manifold, no matter how you hook up an adapter plate?</TD></TR></TABLE>
a/c can be retained with an HF manifold as long as you clock the turbo correctly to work without having to have the compressor outlet facing the a/c compressor. The interesting part is just going to be the exhaust outlet downpipe. You'll either have to be creative with it or make one with a "little" reduced flow so that it'll clear.
Hell, if you look at the outlet on the greddy kits for civics and how cramped IT is, a tight little turn in a fabbed outlet won't matter much.
Also, it'll of course be a LOT easier to retain a/c if you use a smaller turbo than a larger one.
case in point here:
the small one on the left is a mitsu te04h that I have clocked 180 degrees out and you can see it right next to a t3 from a volvo. I think you can tell by the size difference which one will leave more room to play with making a downpipe...
and well, the te04h is efficient to 18psi which is more than the everyday d-series will EVER handle...and will spool faster than that t3 EVER will so it's actually the better turbo for the car anyway.
Old Jul 30, 2003 | 06:26 PM
inspyral's Avatar
T3/T04B:
There's a lot more room to work with the AC though:
Old Jul 30, 2003 | 06:28 PM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: D-series turbo & A/C possible? (inspyral)
you can retain AC with a apexi kit!
Old Jul 30, 2003 | 06:30 PM
GSRswapandslow
Guest
Posts: n/a
what about a custom kit with a Sidewinder manifold???
http://www.lovefab.com
Old Jul 31, 2003 | 07:00 PM
scttydb411's Avatar
i used std/hf manifold...still have ac...and have my turbo compressor on the same side as my ac compressor. you just have to be very creative. i did it this way so my dp is not restricted at all and doesn't put the hot side next to the ac. i didn't want to fry my ac. my ac actually is colder now with the way i reconfigured my setup. check out my webpage for pics:
http://hometown.aol.com/scttydb411/hmtproject.html
Old Aug 1, 2003 | 04:02 AM
dabrown's Avatar
Default Re:
APex kit retains the ac.. It fits as if the car came from the dealership with Turbo. No installations issues. The car is a 98EX Coupe.
I am Lam
Jul 20, 2007 08:28 PM
milton
Dec 14, 2004 11:02 PM
BauleyCivic
Sep 7, 2003 06:46 PM
EKB18BPR3
May 17, 2003 08:26 AM
drvfast
Feb 15, 2003 05:41 AM
