B series?
Old Jul 30, 2003 | 12:26 PM
.dave's Avatar
i HAS questions ?
Default B series?
Anyone ever put a B series into a 4th gen (I think?) Accord. I have a 1991 Ex on its second engine and this one doesn't look like its got too much time left. The automatic transmission is just about dead and theres a ton of coolant and oil leaking out the back of the block. It looks funny as hell but its probably not good. I've seen tons of H22 swaps, but I was thinking of keeping it simple (and cheap) and building up a F22.
Old Jul 30, 2003 | 12:44 PM
miege44's Avatar
Default Re: B series? (dtmamg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtmamg &raquo;</TD></TR><TR><TD CLASS="quote">Anyone ever put a B series into a 4th gen (I think?) Accord. I have a 1991 Ex on its second engine and this one doesn't look like its got too much time left. The automatic transmission is just about dead and theres a ton of coolant and oil leaking out the back of the block. It looks funny as hell but its probably not good. I've seen tons of H22 swaps, but I was thinking of keeping it simple (and cheap) and building up a F22.</TD></TR></TABLE>
if you were going to keep it simple and take the cheapest route, building the f-series or swapping in a b-series wouldnt be what you would do. i'm not saying the f22a isn't a good platform to build on, i'd love to build one up, but cost wise, it wouldnt be YOUR best option (if you're thinking of keeping it cheap/simple)
to gain more reliable power, the h22 swap would be the answer. swapping a b-series into an accord past 1990 is pretty pointless, they lack the torque that a heavier "family" car needs to push it. the h22 has the torque you need. i would say that if you want to keep it simple and cheap your options should be:
1) just swap in a different f22a
2) or swap the h22.
Old Jul 31, 2003 | 01:00 PM
krotchwaffle's Avatar
Default Re: B series? (miege44)
or split the difference and swap an H23 from a 4th gen prelude. it's stronger than an f series, but cheaper than the H22 (providing you can find one), and no need to wire vtec components (to keep it simple).
Old Jul 31, 2003 | 01:23 PM
carolinaACCORD's Avatar
Default Re: B series? (krotchwaffle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krotchwaffle &raquo;</TD></TR><TR><TD CLASS="quote">or split the difference and swap an H23 from a 4th gen prelude. it's stronger than an f series, but cheaper than the H22 (providing you can find one), and no need to wire vtec components (to keep it simple).</TD></TR></TABLE>
I agree. Unless you just really, really want (insert devil word here), I would go with the H23A1 swap. I got mine for $400. Now thats cheap. Put another $1200 or so dollars into it, and you've got a quick car. And that would add up to a little less than what a normal H22A swap would be. The only thing is that you wouldn't have (insert devil word here).
EDIT: A B-series into a 4th gen accord would be much much less than optimal.
Old Aug 2, 2003 | 10:30 PM
CoolWhip's Avatar
Where did you get it for so cheap? Thanx!
Old Aug 3, 2003 | 10:05 AM
Xumarius's Avatar
Dont do a B series. Do a H22 Swap. You can easily get a good one in great condition and have it installed for $3000.
Razz
Nov 24, 2012 07:44 PM
phondataz
Jul 10, 2007 07:25 AM
EvilT
May 11, 2006 02:53 PM
accordtype R
Feb 13, 2006 01:50 PM
c27_accord
Jul 26, 2005 05:51 PM
