75K MILE SERVICE. What to do..
My motor just hit 75k. Im gonna try to do a full service on it. Any suggestions on what i should do? Im gonna do timing belt, water pump, plugs, rotor, distributor, anything else?
oil change, rotate & balance tires, change air filter, spark plugs, cap, rotor, wires, check belts, change water pump, timing belt, tranny fluid, flush radiator, clean throttle body, flush & refill brake fluid. that's all i can think of at the moment as far as normal services
attest53
Mar 5, 2006 08:56 AM
