Brake line question>>>
Here is my setup:
1990 HB
1990 EX Knuckles
1995 Prelude VTEC rotors
Type R caliper
93 Teg rear disc conversion
What SS brakeline set should I use?
Teg?
1990 HB
1990 EX Knuckles
Type R caliper
Teg?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azroth »</TD></TR><TR><TD CLASS="quote">Not to jack your thread, but ITR calipers will bolt right on to EX knuckles??</TD></TR></TABLE>
true i also would like to know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverCRXTC »</TD></TR><TR><TD CLASS="quote">
true i also would like to know</TD></TR></TABLE>
Yes.
And Either 90-91 Si Brake lines or 91-01 teg will work too.
Yes.
If you are lucky enough to find some 1990-1991 civic EX knuckles, then yes the ITR (same as the accord wagon) caliper will bolt on with minor modifications. IMO a better system then the Fastbrakes kit. The EX is the only 4th gen that had 10.2 rotors on it. I then used a 11" 1995 Prelude VTEC rotor, redrilled to 4x100. I *believe* the VW corrado rotor is a 11" 4x100, so I will be using them when I need to replace the rotors I have on the car now.
Does anyone know if the triangle shaped piece that bolts the brakeline to the front shock with the two 10mm bolts is "moveable" on Goodridge brake lines?
My problem is, the stock brakelines will not bolt to my front shocks with the EX knuckles on there. I was hoping to solve this problem when I switch from stock rubber to SS.
you have to shave about 1/4 inch of material off where the caliper mounts to the Knuckle in order for the rotor to be centered in the caliper. Pretty easy to do. I like the setup alot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 »</TD></TR><TR><TD CLASS="quote">
Yes it is.
Yes it is.
W0oT
Nov 6, 2003 04:43 PM
